95 cummins wont shift into overdrive or 4th gear please help
Old Dec 8, 2011 | 05:24 PM
97 cummins 12 valve's Avatar
Default 95 cummins wont shift into overdrive or 4th gear please help
my 95 cummins has recently had pump and timing work beause the timing slipped now that she is going again it runs great to third gear but wont shift into 4th it will kick into overdrive for a sec then shift out then back in and out i was wandering if this could be a torque converter or trans or turbo plz help
Old Dec 8, 2011 | 06:53 PM
turbo2332's Avatar
no turbo for sure. what are the specs on your tranny? is it all stock. is this at a low speed or highway? when my TC went out it was chattery as hell but didnt hunt for gears much
Old Dec 9, 2011 | 02:23 PM
smokedout's Avatar
Its your tps
Old Dec 9, 2011 | 04:32 PM
Torkjunky's Avatar
Mine did the same it was the TPS, they are pricey but I cleaned mine and work like a champ. He is the instructions on cleaning, bout have way down the page.
Dodge diesel maintenance tips
Old Dec 9, 2011 | 04:55 PM
gwhammy's Avatar
You can replace the tps with a potientiometer (may not be spelled right) and it will make the tranny go into od and lockup at a set speed. About a 3 to 10 dollar fix from radio shack.
Old Dec 9, 2011 | 06:20 PM
Billy D's Avatar
Great info Thx
Old Dec 10, 2011 | 03:55 PM
Scott R.'s Avatar
i had the same problem turned out the converter was bad also the shift cable was worn out pretty bad replaced both and works fine now.
Old Dec 13, 2011 | 08:34 AM
thanks everybody i think it may be the tps i will check it out tonight and let every one know what i find
diesel_fireman20001
Basement Enterprises
15
Dec 18, 2018 08:59 PM
EverettsGMC
Mar 29, 2015 05:42 PM
rabidrabbit
Mar 6, 2015 03:47 AM
aoutlaw95
Mar 3, 2015 09:02 PM
Oct 28, 2014 08:10 AM
