Gauge questions???
Old Dec 8, 2011 | 01:29 PM
Chinuck's Avatar
Default Gauge questions???
So I know questions about gauges are always being brought up so I do apologize but I was wondering what psi boost gauge I should use and what tranny temp range I should use I have just a intake and exhaust right now but bout to get my new ip pump and air dog and really as far as performance I might add a chip I'n the future so any advice is good
Old Dec 8, 2011 | 01:40 PM
RAW's Avatar
RAW
Boost:
0 - 30 psi for bone stock, 0 - 60 psi if you plan to push more air in the future.
Trans Temp
100 - 250 should cover you.
Doesn't hurt to have pyro (exhaust temp) gauge as well. 0 - 1600 or 0 - 1800 is a wide enough range.
Old Dec 8, 2011 | 02:53 PM
Chinuck's Avatar
Yeah I was plannin on a pyro and fuel pressure as well just wasn't sure bout those two
Old Dec 8, 2011 | 03:59 PM
RAW's Avatar
RAW
Fuel pressure is the most important. Low transfer pressure to the VP44 will quickly end the VP's life.
Old Dec 8, 2011 | 05:37 PM
Chinuck's Avatar
I know sadly I lost my vp bout a month ago and the trucks just been sitting but should be goin into the shop on the 15th
Old Dec 8, 2011 | 09:46 PM
bristoy's Avatar
i' suggest if you can get the 0-60 psi boost gauge.i got a 0-35 and with my current set up i almost wrap the needle around to the stop hitting more than 45psi.the problem is i got Autometer Luna series,they discontinued making & now can't get the 0-60 or 0-100.i only plan on adding more power so i'll need the bigger one but don't want to change all to match.
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
mt_wi86
Oct 7, 2014 01:13 AM
