turbo problem
Old Dec 8, 2011 | 11:39 AM
97 dodge 12 valve's Avatar
Default turbo problem
my turbo is spinning and can hear it but no boost pressure and oil comeing out the intake side of the turbo help please
Old Dec 8, 2011 | 06:55 PM
turbo2332's Avatar
the bushings are out of your turbo. you should still get -some- boost though? sure there isnt any blow rubber connectors or anything. but if your turbo is no longer spinning as fast as it should be your #'s will be WAY down. time for a rebuild or an upgrade.
Old Dec 8, 2011 | 09:41 PM
cummin_un_glued's Avatar
FormerVendor
i'm gonna say its the shaft is broken, the comp side can still spin some even with the shaft broke
Old Dec 9, 2011 | 07:33 AM
turbo2332's Avatar
ugh.. i hope its not that. take your air filter off and see if the wheel wants to come out.
Old Dec 9, 2011 | 08:30 AM
97 cummins 12 valve's Avatar
well last night i took my air filter off and the fan was spinning good does this mean the bushings or shaft could still be bad? i hadnt read these till just now so i will try to pull it and see if it wants to come out
Old Dec 9, 2011 | 09:02 AM
turbo2332's Avatar
if the fan spins the shaft isnt broken. is there excessive shaft play.
Old Dec 9, 2011 | 09:05 AM
there is some play but not much moves up and down just enough for you to fill it move is this because the bushings?
Old Dec 9, 2011 | 11:05 AM
turbo2332's Avatar
its suppost to do that???
Old Dec 9, 2011 | 11:54 AM
NadirPoint's Avatar
Seal gone. You should rebuild or replace the turbo and have a look in the intake horn to see how much oil it's been injesting - just for shyts 'n grins. Maybe need to flush the intercooler.
Old Dec 9, 2011 | 12:57 PM
what seal i have never tore apart a turbo or had to rebuild one, just took them on and off. should i just get a rebuild kit?
