2003 Not Starting Cold
Old Dec 8, 2011 | 07:36 AM
TRESTER's Avatar
Default 2003 Not Starting Cold
My 03 is not wanting to start when its cold. (45 and lower) The air intake heater is working. If i don't plug it in I must use starting fluid & it fires right up.
I was told its the injectors. Anyone disagree?
I bough it used, it has 325k miles & i don't know if it has newer injectors.
The truck is stock besides exaust & air cleaner. What size & brand injectors can get me the best MPG?
I have owned several new built 7.3 powerstrokes, this is my 1st cummins
Its a 4x4, auto, 4-door, 3:73, and gets 16-19 MPG.
Old Dec 8, 2011 | 09:42 PM
mudstud9258's Avatar
Shot ether in my 03 for 2 years, hot or cold. Was told injectors were shot. Then I changed the serp belt, wiggled the crank sensor, cleaned connectors and grounds and fires up everytme. Runs great, Got 25.7 mpg on a recent trip and 14+ pullng 45' 33000#gvw livestock trailer. Just my experience. My first cummins was a 92,bought new and it still runs at 640000 miles. only repair was a bearing in tranny. Right front wheel shudders so bad between 30-35 it throws the passenger side door open. Shifter is a piece of pipe and if u hit a bump the driver wndow falls inside the door...Loved that truck, gave her away and still running in texas.
Old Dec 12, 2011 | 02:24 PM
LHartman's Avatar
"Could" be injectors. When my injectors started to go it was hard to start cold, until finally it wouldn't start at all.
GasItOut
35
Jul 22, 2015 01:11 PM
Mike0885
May 27, 2015 12:07 PM
91 7three
Jan 7, 2015 09:37 AM
custom7.3
Nov 24, 2014 05:16 PM
12vbomber
Nov 4, 2014 10:04 PM
