timing gear alinement HELP, HELP
Old Dec 7, 2011 | 05:14 PM
tedge's Avatar
Default timing gear alinement HELP, HELP
Removed my injection pump weeks ago and skipped a tooth on the injection pump to cam gear while putting back together. Does any one know where i can find the correct timing for the injection pump . Have the letters D E C on pump gear and only one of thoses should be in line with the (O) on the cam gear. The timing cover is off truck so i can see every thing clearly. The different letters are for different applications Mine is a 1993 dodge auto trans. HELP.
Old Dec 7, 2011 | 06:11 PM
cummins4ever's Avatar
I'm not sure if a 5.9 is the same as a 8.3 cummins hopefully someone will correct me if I'm wrong but I think there is a dowl pin behind the pump pull it out and turn the engine over by hand untill the spot where dowl pin goes into lines up then push dowl pin in and turn the engine bit by bit untill it pops into place. Then throw it back together. But like I said Im not sure if it's the same as a 8.3 cummins I've never pulled 1 off my 5.9 but that's what I know from working on a 8.3l
Old Dec 7, 2011 | 07:13 PM
BC847's Avatar
That simply brings cylinder #1 to top-dead-center.
- Stock timing at the gears is O to E.
- One tooth advanced is O to C.
If you're wanting to put the IP timing close to stock/OEM with the pump advance one tooth you'll need to pull the pump back such that the IP mark is about 1/4" to 3/8" or so before the case mark. That will put you in the ballpark.
Old Dec 8, 2011 | 09:51 PM
tedge's Avatar
Thank you for the help on the timing marks, bc847 You are a life saver.
Old Mar 29, 2014 | 04:57 PM
wrench8x's Avatar
Default 5.9 timming problem
I have a 5.9 94 mod with p pump pulled pump to put gasket on lifter cover.when i got the timming pin in and took nut loose to pull pump,there is no keyway in gear.but there is in pump how does it stay in time,when u loosen the nut?I would think if is on a lobe it would turn a little.any help would be great,thank wrench8x
dango
Jun 21, 2016 01:13 PM
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
Spiderman
Oct 6, 2014 09:52 AM
