4x4 not workin...
Old Dec 7, 2011 | 01:10 PM
mabry1's Avatar
Default 4x4 not workin...
Hey guys, I have an 01 24v and having 4wd problems. It will shift into 4hi fine and the light comes on but its not ingaging? I have vacuum at the front axle in both 2wd and 4hi. When I move slow it does nothing butt if I give it a little blast of pedal I can hear the gears grinding like it wants to go in.
Any ideas or help would be much appreciated!
Old Dec 7, 2011 | 08:02 PM
Whit's Avatar
Site Mascot
pull the cover off the front axle and take a look sounds like maybe the 2 lil tabs off the shifting fork may be busted off or possibly worse........the cove is easy to pull but if I remember right you will loose just a bit of fluid
Old Dec 7, 2011 | 08:15 PM
mabry1's Avatar
Thanks! Ill do that in the morning and see what I come up with. I'm guessing the transfer case and linkage are fine since when I shift it into 4hi the front drive shaft doesn't spin by hand. I'm woundering also if the accuator could be bad??
Old Dec 7, 2011 | 10:25 PM
cumminsera's Avatar
my 4 wheel drive engages but its doing the same as yours, light comes on and everything but idk cant figure it out, and i noticed i am having a little vibration on and off while driving
Old Dec 8, 2011 | 09:44 AM
aguilar_15's Avatar
Had this happen a few years back. What happened to mine was the shaft disengaging and pretty much just floating around in the axle. Also made a noise that sounded like pennies in a dryer. Might want to check the shafts at the knuckles.
Jan 20, 2015 03:01 AM
DIESELDENT
For Sale
Dec 19, 2014 06:53 PM
Dec 7, 2014 11:20 AM
mabr0503
Nov 27, 2014 01:36 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
