Ever see a check engine light go off
Old Dec 7, 2011 | 12:39 PM
Jimmysd's Avatar
Default Ever see a check engine light go off
What could it mean, is the problem no longer. I had some issues, four codes. replaced the ficm. Ran better only one code Po 0283 after replacing ficm. One thing, I was checking the wire harness to the ficm for the most coming chafing points per ford. I noticed when i moved the wires harness under the ficm a little to the left of it. I heard a click and the engine revved a little hire. Sounding pretty good though. So i went and put some new diesel in and fire power. On my way home I jumped on it a couple of times and it had good response. When I got home I noticed the check engine light was off. Could this mean it might have been the wire harness and not a injector? Does the computer check itself continually? and if a problem is no longer it resets itself. Or is this just wishful thinking.
Old Dec 7, 2011 | 12:45 PM
03Powerstroke's Avatar
if the ficm wasnt fully connected it can make the truck do a bunch of weird stuff
Old Dec 7, 2011 | 01:09 PM
The hosser's Avatar
i have had codes clear it’s not uncommon.
Old Dec 7, 2011 | 01:41 PM
Mdub707's Avatar
Yeah if you mistakenly "fixed" something under the hood it certainly could have went away. The truck is constantly scanning/reading things. I can definitely clear a code on it's own. Chances are there is still something stored there, but the check engine light itself is gone.
03powerstroke is right, it's AMAZING how poor a 6.0 will run with a clip just SLIGHTLY undone on the FICM.
Old Dec 7, 2011 | 06:02 PM
Jimmysd's Avatar
well it came back on. But i am thinking I have a harness issue. Like i said when i moved the harness i heard a click and the engine revved up. mane a perfect idle.
Before when I had the one code, when i came to a stop the engine would seem to die down.
After the movement of the harness and click, at a stop it still idled strong.
I will keep play with it , hope i can get it to stay if not I think I will be changing the harness. Is it real hard or just a couple of connections. I know the 8 for the cylinder and the two for the ficm
When I was researching all this I see ford came out with a new harness with them separated The one is for the ficm power and the other two wrapped together are for the cylinder. Is this true for my 04. Otherwise I will have to get the whole three wrapped together which is pretty pricey
Old Dec 8, 2011 | 07:19 AM
Mdub707's Avatar
They are two separate harness' on all of them I believe. At least on my 06, there is a harness that goes from the PCM to the FICM, then there is a harness that goes from the FICM to the 8 injectors. That one isn't hard to do at all, and I've heard of them causing issues before as well.
What was the code it was throwing, that will probably tell you where you need to look.
Old Dec 8, 2011 | 08:58 AM
Jimmysd's Avatar
Po 0283 was the only code
Old Dec 8, 2011 | 09:23 AM
Mdub707's Avatar
That's an electrical code for #8 injector. I would check out the harness very well going from that injector to the FICM. That injector is on the drivers side closest to the firewall.
Old Dec 8, 2011 | 02:33 PM
Jimmysd's Avatar
i just flushed the antifreeze. Figure better do some maintenance before any other problems.
I was just going to ask which injector
Thanks Mdub707 and thank you to everybody else also
ford dealership what a joke. I just noticed what looks to be duct tape on the #8 injector cable. Thats what they call a recall . What a joke.
Old Dec 8, 2011 | 02:54 PM
Mdub707's Avatar
WTF? You can take it off and take a real good look at the wires, but those things are so finicky I feel like you're going to need to just buy another one. Maybe look for a good used one on ebay or the forums.
