Advice Appreciated
Old Dec 5, 2011 | 10:59 PM
adub12valve's Avatar
Default Advice Appreciated
Need some advice about improving mpg's. Would some better injectors help? And I konw my tires arent a good thing but they were free. Thanks guys
Old Dec 6, 2011 | 04:14 AM
Sudia247's Avatar
Yes, some injectors would help, along with a cam, water methanol injection, gears, and fuel pump timing.
Old Dec 7, 2011 | 12:13 AM
What should the timing be around? and would 4k gsk help? And what gears would you suggest?
Old Dec 7, 2011 | 02:31 AM
Sudia247's Avatar
If you have the factory head bolts still, no more than 16.5* of timing. I would definitely recommend 4k gsk, they fuel more, and creates a more sensitive throttle, a plus, but they won't help your MPG.
Gears wise, it would depend on what tire size you have, and what you want to use the truck for.
Old Dec 8, 2011 | 11:57 PM
Ok I was looking at those. And I will do timing, the tires are 35's and I haul not all the time but frequent but its my DD. And I believe the gears are 410's
Old Dec 9, 2011 | 09:38 PM
keithduke01's Avatar
3.50 gears would definitely help the fuel mileage, i went from 18 interstate with 4.10s to 22-23 with 3.50s but the 3.50s will work the transmission harder when pulling or in 4wd so keep an eye on tranny temp if you switch gears, and make sure to do both differentials, i hate saying that but some people still make that mistake!
Old Dec 10, 2011 | 03:45 AM
Sudia247's Avatar
4.10's are good if you do a lot of stop and go driving. But 3.55's will be better if most of your driving is highway, and as stated above it will work your tranny harder, so giving it some attention would be advisable. I have 3.55's with 37" tires, I get about 25 - 26 mpg hwy.
Old Dec 10, 2011 | 12:59 PM
BramanteCummins's Avatar
^^^ your trans must love you for that
Old Dec 12, 2011 | 04:09 AM
Sudia247's Avatar
I don't have a heavy foot =) so it's still holding up fine, Ill definitely buy some 4.10s down the line though.
Old Dec 12, 2011 | 11:18 PM
4:10s re great and all, its the only thing keeping me from going faster than 100 besides oem gov. springs hah
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
twm011
Feb 24, 2015 09:11 AM
Mikeyfz45083
Transfer Sled Pulling
Nov 14, 2014 11:04 AM
lifted07sierra
Nov 6, 2014 08:24 AM
