Slow idle
Old Dec 5, 2011 | 03:18 PM
Colton Carter's Avatar
Default Slow idle
My 96 cummins has a slow idle I was told. Where and how do I adjust it?
Old Dec 5, 2011 | 04:11 PM
vexxxed's Avatar
Hey Colton,
I just did mine yesterday because I was idling around 500 RPM in drive without the AC on. I looked around and found a few of these tutorials. One tip I recommend is to sit on the radiator support and look down the driver side of the block and you can see behind the linkage really well. Its a vertical bold that has a lock nut on the bottom side and the top bolt is on top of a little metal piece that is connected to the injection pump. Read over the tutorials a few times before you jump into it. Idle should be set around 750-800 in Drive WITH the AC on. Good luck!
One tutorial:
https://www.dieselbombers.com/12-val...lve-p7100.html
And another with pictures. I recommend this one.
Ram Diesel Problems
Old Dec 5, 2011 | 05:10 PM
Thanks a ton vexxxed!
Old Dec 5, 2011 | 09:47 PM
vexxxed's Avatar
Not a problem! Here to help!
ruben24
Sep 10, 2015 04:21 AM
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
