Another 47RH Problem
Old Dec 5, 2011 | 01:28 PM
bigdan120's Avatar
Default Another 47RH Problem
Hey Guys maybe you can shed some light..... If I take my truck out and run it up to 2 grand and let it shift it shifts hard and shifts are close when it hits lock up it like BAAAAAAAAAA with Smoke LOL and it drops RPMS from 2000 to 1500 with the OD off......When it is on it shifts hard but long in between all 2nd and 3rd but after that it shifts lazy. Not slipping just lazy. Changed Pot.. Changed temp sensor........It used to lock and unlock with the wind until I replaced the Temp switch.............Fluid smells burned but im guessing it from pulling my camper Still red ......2 hours down the Turnpike BAAAAA ummmmmmmm BAAAAAAAA UMMMMMM BAAAAA annoying as hell LOL help!!! I have a trans go kit.... sonex kit, billet tri disk, billet input, 5.0 strut.......All kinds of red aluminum goodies in the bottom...For lack of parts names....
Old Dec 5, 2011 | 02:27 PM
mysterync's Avatar
Line pressures? Throttle valve adjustment?
Old Dec 12, 2011 | 08:40 AM
bigdan120's Avatar
Default Got it
Well seems to me that when I get busy I don't do thing correctly..I put a new TPS on it awhile ago and did not check it. I did adjust it all the way forwards but I guess it wasn't enough..... So I drilled the holes in it and moved it forward all the way and it works good along with moving the De-tent cable....I had to tighten it up ..It had slack in it...Everything's good now....Surprising how much I can mess up in a short time LOL
Old Dec 12, 2011 | 12:09 PM
tower_ofpower's Avatar
If your TPS craps out out on you again dnr customs sells a "delete" kit for it. It's just a potentiometer you set and leave it.
Old Dec 15, 2011 | 09:14 PM
twinstang's Avatar
Who is dnr and do you have contact info for them.
Old Dec 15, 2011 | 10:22 PM
chrislib's Avatar
Welcome to DNR customs
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
Dadslb7
Dec 9, 2014 11:05 PM
