clogged injector?
Old Dec 4, 2011 | 09:28 PM
dipapadakis's Avatar
Default clogged injector?
im thinking i might have a clogged fuel injector i put my 181 delivery valves back in my pump and idle runs fine at about 7-800 rpm but when i drop it in gear when its cold it drop to like 3-400rpm and after its warm like 450-500 rpm
Old Dec 4, 2011 | 10:23 PM
mysterync's Avatar
Turn your idle up
Old Dec 4, 2011 | 11:24 PM
HydroElectric's Avatar
what mysterync said
Old Dec 4, 2011 | 11:41 PM
is that normal when downsizing in dvs i just started the truck its about 45 degrees out n it was cold n when its in nuetral its at 800 n in drive it almost dies its down at like 250 and surging never did this with the 024s how high should i set the idle at if it was a clogged injector wat would i notice?
but once its at running temp its at 450/500 in drive
Old Dec 6, 2011 | 12:43 AM
bump?
Old Dec 6, 2011 | 08:54 AM
mysterync's Avatar
Adjust you idle and then determine if issues are still present.
Old Dec 6, 2011 | 10:52 AM
k will do
lowride
Oct 24, 2015 08:50 AM
Dkolanski06
Apr 23, 2015 09:32 AM
2ndcummins1
Mar 9, 2015 10:01 AM
amztroyer
5.9L 24V Performance
Mar 5, 2015 05:02 PM
J_stout
Dec 14, 2014 07:23 PM
