Allison swap
Old Dec 4, 2011 | 08:50 PM
Colton Carter's Avatar
Default Allison swap
Would a Allison transmission bolt up to a 12 valve?
Old Dec 4, 2011 | 09:10 PM
somkingcummins95's Avatar
not an easy job and i wouldnt recomend a allison they stall to bad with more power but you would have to buy adaptor kits and computer modules its alot but i would sugest just a good shift kit for your stock tranny depending on the power you want to put to it or maybe a vaulve body but it would be half the money and half the aggervation
Old Dec 4, 2011 | 09:12 PM
Okay. If I change my auto can I put a 6 speed in it?
Old Dec 6, 2011 | 07:27 PM
allison? yea i think it would work it should
Old Dec 6, 2011 | 07:43 PM
monster12valve's Avatar
i would do a nv5600.....6 speed manuel
Old Dec 6, 2011 | 10:56 PM
tower_ofpower's Avatar
PATC trans has the adapter plate needed for the Allison swap. Can't recall if you'd need a different flex plate or not. From what I hear Allisons are some towing sob's but they don't like gobbs of torque. If it's a stock-ish truck that you'd get plenty of utilization of the 6 speeds for towing then it may be worth while. You'll also need a stand alone controller. Which translates into $$$
Old Dec 7, 2011 | 11:21 AM
dan33klein's Avatar
about 5-6k to put in an allison minus cost of trans and transfer case
Murdock
Apr 12, 2015 06:16 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Jgloveracob
Nov 16, 2014 07:27 AM
gunslingerburkhart
5.9L 12V Performance
11
Oct 19, 2014 08:42 PM
wisakowsky
Oct 14, 2014 08:13 PM
