ford4x4fan
Old Dec 4, 2011 | 08:12 PM
ford4x4fan's Avatar
Default ford4x4fan
Hi everyone. I'm new here and not very good with the computer so please forgive me if I am in the wrong place on this site. I have a problem with my 04 F250 Crew Cab Short Bed with a 6.0. I have had it about a year and it has a Banks Six G?un with Speed Loader, AFE Air Intake,Banks 4" exhaust. I just had it in a shop where they did the following: Blocked EGR valve and replaced the cooler with a good used one, replaced oil cooler, heads,head gaskets, ARP studs,intake manifold gaskets,injector seal kit,fuel housing gaskets,oil and filter, oil pressure sending unit, oil filter cap, coolant/additive, coolant reservoir,CAC Boots, radiator hoses, glow plug harnesses,timing belt,exhaust manifold gaskets, thermostat Bypass Hose and port plugs!! Got the truck back yesterday and this morning it would not start!!!! I AM NOT A HAPPY CAMPER!!! I did get ahold of the shop and they are sending a tow truck in the AM but have already said they don't think it is anything they did or didn't do. He was talking about the high pressure oil system or the FICM. Does this sound correct to any or all of you guys? I am wondering if I got ripped off and not sure I should let these guys have my truck again
Old Dec 4, 2011 | 08:56 PM
gunman41mag's Avatar
Moderator
Did your truck throw any codes ???
Old Dec 5, 2011 | 07:55 AM
Mdub707's Avatar
First question, is there any smoke coming out the exhaust when you try to start it? If not, then it's a high pressure oil leak or a FICM like the shop said. Let us know if there is smoke or not first and we can go from there. I can't believe they did all that work and didn't update the common high pressure oil problem areas. I'm doing this job soon myself and I will be replacing the stand pipes and dummy plugs with the new models, and doing the STC fitting on mine as well, all very common areas for leaks and all have new updated Ford parts, and they're not that expensive.
If it is FICM related, I can fix it. I can also help you test it on your own, but first let us know if you're getting smoke or not.
Thanks, and welcome to the site!
Old Dec 5, 2011 | 08:17 PM
ford4x4fan's Avatar
Default not starting
Thanks for answering guys but since I didn't know to look back at my own message for a reply,{ looked on the weong page here} I went ahead and let the shop come get my truck hoping it was something they did or didn't do and it wouldn't cost me anything. WRONG!!! They told me it is the FICM and would cost $1000 to replace it. Does that sound right? I don't have much choice now but if I'm getting ripped off I need to know. This place was recommended by a guy I met who had work done there and trusts them. This AM the tow truck driver was the same one who picked up the truck the first time and recognized it as he drove up. It is never a good sign when tow truck drivers know your truck on sight! LOL.
Old Dec 6, 2011 | 02:19 AM
jeffa6980's Avatar
You might want to check ebay and maybe install it yourself if you can. If im searching for the right part it looks to be around 400 dollars on there. i found it as low as 250 plus 150 core charge. Good luck.
Old Dec 6, 2011 | 07:24 AM
Mdub707's Avatar
Ford FICM: $900 new without programming
Ford FICM half shell: $400
Swamps rebuilt units: $450 or so, plus $300 core
There are other options...
Much cheaper options...
I'm sending you a PM.
Old Dec 6, 2011 | 08:11 AM
jeffa6980's Avatar
thanks mdub for the info
Old Dec 6, 2011 | 10:42 PM
stone's Avatar
After you replace the ficm i would get rid of that 6gun tuner, they are notorious for destroying ficms on 6.0s
Old Dec 7, 2011 | 07:19 AM
Mdub707's Avatar
I thought it was PCM's they ate...
Old Dec 7, 2011 | 09:22 PM
stone's Avatar
Your right Mdub they do, but i was under the impression 6guns and TS chips killed ficms just like the older strategies did? If im wrong sorry
