Winter start up help
In the colder weather I have to press on the accerlator a little when it's cranking over and hold it for a while to get it to stay running. Is this normal??? Thanks
lfold down your driverside sun viser &read what it says there about cold weather starting.i believe it gives instructions as to this &it's normal.i have an 89 w/95 motor &unless i have it plugged in i have to use the throttle too.
Pretty normal for the p pump they can be a pain in the *** to start in the cold I had to jump our 98 12v and start it 3 times pushing the pedal and it was only 3 below, now my 93 starts like a dream no matter what last year I started it on the coldest day of the year at 28 below with a 50 below wind chill with out even being pluged in and no ether, fired up first crank but it billowed smoke for like 30 minutes.
I start my cummins year round with the throttle just cracked and then let off once it starts and i live in Florida. i cranked the governor springs in a bit too much and ever since it starts easier this way, its not hurting anything and your truck doesn't have anything wrong either. I wouldn't worry about it, I spend a solid minute starting my truck every day
. gotta pull the string thats tied to the bad fuel cutoff solenoid, insert any key, press brake(no park brake and i park on a slope), clutch, crack throttle(3 feet would be ideal), start, flip separate switch for radio, separate switches for headlights and running lights if its night time
. its a process. when i get in my other truck i initially want to crack the throttle and i end up looking for a string under the dash.
