How to install a stack?
Old Dec 4, 2011 | 04:20 PM
Colton Carter's Avatar
Default How to install a stack?
I want to know how hard is it to install a single stack and how much is it usually? What's the best brand and best sounding? The truck is a 1996 cummins 2500 thanks.
Old Dec 4, 2011 | 04:36 PM
monster12valve's Avatar
easy install takes couple hours if u weld everything instead of clamps. u need a stack of ur choice..i have an 8" mbrp, you need a 90* elbow and a sawzall and a whole saw. easy as pie.
Old Dec 4, 2011 | 04:56 PM
Should you weld it or use clamps?
Old Dec 4, 2011 | 06:13 PM
totally up to u either will work
Old Dec 4, 2011 | 06:15 PM
Is the Noise bad in the cab?
Old Dec 4, 2011 | 06:17 PM
i have an 8" and it stayed on for 3 days before i took it off. it was untolerable. couldnt use the phone....or have a convo with a passenger. i have reg cab.
Old Dec 4, 2011 | 06:19 PM
Is the truck mostly stock?
Old Dec 4, 2011 | 06:23 PM
no but it will be just as loud on a stock truck if u go with a straight pipe.
Old Dec 4, 2011 | 06:24 PM
Straight pipe?
Old Dec 4, 2011 | 06:26 PM
no muffler and no catalytic converter....just a straight pipe from the turbo back.
