hp range
Old Dec 4, 2011 | 03:25 PM
stackboy6.9's Avatar
Default hp range
#10 plate
140 hp injectors
delivery valves
4k gov springs
60lb valve spring
phatshaft 71 non wastegate turbo
tuned injection pump
airdog system
4in exhaust to dual 5in stacks
can i reach 450hp with this set up
Old Dec 4, 2011 | 04:29 PM
monster12valve's Avatar
depends on ur trans
Old Dec 4, 2011 | 09:21 PM
EasternAggie's Avatar
As long as your trans can hold it, it should definately get you to 450hp. I would think about head studs and orings before too long also.
What size Super PhatShaft are you thinking about? I would go 64 for that much fuel.
Old Dec 5, 2011 | 06:49 PM
turbo2332's Avatar
i dont think you will like that turbo. kinda on the big side
Old Dec 5, 2011 | 10:58 PM
It has a 6speed manual.what turbo should I run then
Old Dec 6, 2011 | 09:21 AM
turbo2332's Avatar
prolly a 64, when i spend the cash on a new turbo im lookin at a 62 with a goal of 500hp
Old Dec 6, 2011 | 11:18 AM
Farmboy 2.0's Avatar
Yeah you would need to look at a silver 62 to silver 64. That silver 71 will be a laggy hot smokey pig. And you may finally get that charger to light around 3000rpm.
Old Dec 7, 2011 | 02:36 AM
Sorry I thought by 71 he was referring to turbine size, didnt know II made a 71mm compressor turbo. And ditto on a 71mm comp being laggy, I think it would be a sled pulling only turbo on a 12v.
Sep 8, 2015 02:40 PM
Jun 4, 2015 09:30 PM
Apr 15, 2015 04:30 PM
Mar 19, 2015 07:10 PM
Feb 23, 2015 06:20 PM
