Vibrating Front End
Old Dec 4, 2011 | 12:29 PM
Bucholz's Avatar
Default Vibrating Front End
My 2005 Dodge 2500 is making a vibration noise in the front end somewhere. It only does it when i take off from a stop, let the rpms drop low in a high gear and stomp on it, or when im braking. This problem is driving me crazy so any ideas will help.
Old Dec 4, 2011 | 04:54 PM
sillyneck's Avatar
Miles? any suspension mods? if so what
I'd look at the front pinion bearings first. best way I've found is to put all 4 corners on jack stands... drop it in gear and give a walk around.
then the usual balljoints, axle u-joints, and drive shaft joints and cv. with it off and on the jackstands pry around on everything and see if anything has excessive play.
Short of that it's really hard to think it's coming from the front end.
Old Dec 5, 2011 | 12:20 PM
Bucholz's Avatar
It sits stock. I replaced the ball joints and the hub assemblies cuz they were shot. It has 113,000 on it
Old Dec 5, 2011 | 01:03 PM
RanchhandTCR's Avatar
Id jack up your truck enough to be able to but a pice of wood to push on your side wall and look and feel for movement, if they wiglle excessivly you wheel bearing need to be replaced. You can also spin your tires and listen for any unusuall noises...
Old Dec 5, 2011 | 11:37 PM
Bucholz's Avatar
I replaced the wheel bearings when I replaced the ball joints
Old Dec 6, 2011 | 09:18 AM
sillyneck's Avatar
Gotta love that stuff. Last one I diagnosed for a funny sound was a new unit bearing (100miles) that was garbage. I think he didn't seat the stub shaft enough and the bearing began to seperate... then he tightened it... then took it to me and didn't want me to know. Sometimes new parts are just junk so you might want to look it all over again.
Old Dec 6, 2011 | 02:35 PM
dipapadakis's Avatar
i think its the motor buy a duramax...
Old Dec 6, 2011 | 04:11 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Trac bar bushings, control arm arms, tie rods???
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
2FordStrokers
Jan 11, 2015 09:40 PM
Cumminsman911
9
Nov 1, 2014 04:07 PM
