What if??
Old Dec 4, 2011 | 02:06 AM
globalwarmingcontributor's Avatar
Default What if??
If I was to use my stock turbo..hx35, and a possible s300 as a COMPOUND turbo, would that work? How would I set that up? Anyone made a homemade COMPOUND set up? What all would I need?
Old Dec 4, 2011 | 01:29 PM
01quadcab's Avatar
just run the 300 as a single and save up for a 475 or similar to run on bottom. even a 465 would be nice. but your best investment for the cash is get rid of the superchips and get a edge comp since you have gauges.
Old Dec 4, 2011 | 01:56 PM
i agree. ill be getting an edge comp before i come home from korea. but also looking to make my own COMPOUND set up. have people in the past got pipes custom made for COMPOUNDs? and had special mounts made for second turbo?
Old Dec 9, 2011 | 12:01 AM
used edge drag comp for my truck....200 bucks...good deal? or good deal!!!! all wires look to be there, just no instructions. but i can get them online im assuming ..THOUGHTS?
Old Dec 9, 2011 | 08:23 PM
01quadcab's Avatar
seems cheap probably needs sent in and repaired for another $100 bucks. But still a good deal at 300
Old Dec 9, 2011 | 10:46 PM
RAW's Avatar
RAW
I made my own COMPOUNDS with a stock HX35 and a S400. Works awesome, excellent driveability, and less then $700 as the S400 fell in my lap.
Old Dec 10, 2011 | 03:28 AM
first off, congrats on your baby! we just had our daughter dec 8th. when i send it in, its only 100 bucks to repair it? you know about the hot unlock? i wonder how much that costs???!!!
i may be stumbling upon a good used hx40, for next to nothing.. its not possible to run that as a compound is it? how did you mount the other turbo? i really wanna make my own compound set up, just completely retarded in this department.
Last edited by globalwarmingcontributor; Dec 10, 2011 at 03:28 AM. Reason: Automerged Doublepost
Old Dec 10, 2011 | 05:15 AM
RAW's Avatar
RAW
This may help:
https://www.dieselbombers.com/5-9l-2...urbos-2-a.html
An HX40 is too small for a compound set up. Better off making an HX35/40 hybrid with the HX40
Old Dec 10, 2011 | 06:21 PM
01quadcab's Avatar
thanks man congrats to you too. If you found an actual comp hot that is the unlock... usually repair runs $100 and you send it in they send it back.
Old Dec 11, 2011 | 05:55 PM
cool thanks bud..if i get it, ill send it in and get it repaired before i get it on my truck.
