Control Arm Qs
Old Dec 3, 2011 | 11:07 PM
JRHoward's Avatar
Default Control Arm Qs
I put a 6.5 inch lift from stock height on my cummins, It was a homemade lift and I am now working on making control arms but I dont know how much length to add to the stock length?
I cant take the truck apart and measure as I go because I need it basically daily and in a small town every one is closed on the weekends so I need to have it all prept before starting. If anyone would know or how to figure it out i would appreciate. As you can see from my pics with my 38s on I dont have much for turning radious. Thanks for any advice.
Old Dec 3, 2011 | 11:50 PM
man754's Avatar
call up topguncustomz.com and ask them what the length of theres are and go from them if not they make a complete set a arms for like 250 bucks.
Old Dec 4, 2011 | 05:21 PM
JRHoward's Avatar
k thanks i never thought about that...Ya 250 is still a bit out if my price range...I am hoping to keep these under 50 buck. I enjoy figuring and working on my truck so time isnt a concern much. Thanks
Old Dec 4, 2011 | 06:24 PM
man754's Avatar
Well if it helps i just measured my control arms for a 6 inch on my dodge and the lower arms measured 19 5/8 center of eyelets and the tops are 18 3/4 inch center of eyelets.
Old Dec 5, 2011 | 07:54 PM
JRHoward's Avatar
K, I measured my stock and roughly(doing it in the dark) the bottom is 18 1/4 and the tops 17 3/4. So I will just add the difference to my new ones...Thanks a lot that was basically what I needed to know. I will post pics once I get em finished up.
Old Dec 5, 2011 | 08:40 PM
man754's Avatar
i measured mine from the center of the bolt holes. just so you dont get confused but make sure to build a drop bracket for your trac bar. it will throw your steering and alignment all of. if any other questions about the lifts let me know after doing mine i figured out a bunch of little nick nacs on doing them
Old Dec 6, 2011 | 11:25 PM
JRHoward's Avatar
Ya, I learned the hard way about the track bar...I actually built a 3rd gen style bracket and a track bar with bushings on both ends and exstended the bar to make is centered. I do have another question...my u joints on my front drive line hits on my front end when in 4 wheel drive because of the angle. What would be the best way to fix that?
Old Dec 10, 2011 | 12:29 AM
JRHoward's Avatar
How high does your dodge measure off the ground? Measuring from the wheel wells...I am trying to figure how much of a lift I have...I have 6.5 inches from stock hightower, I don't know if that translates to a lift. What size tires you have on?
Old Dec 10, 2011 | 09:52 AM
man754's Avatar
The spacers i put on my front end measure 6 inches with out the isolater. my tires are 36/15.5/16s i can fit 38 without any rubbing issues.the fenders measure 46 to 46.5 i cant really tell cuaes of the fender flares i put on
Old Dec 11, 2011 | 10:07 PM
JRHoward's Avatar
K...hopefully in a week or two I can get my 38s back on and I will measure. Thanks...did you have to build a drop bracket for your front end so your drive line doesn't hot?
