wanna p-pump my 24 valve
Old Dec 1, 2011 | 06:39 PM
2001BlackMagicCummins's Avatar
Default wanna p-pump my 24 valve
I wanna p-pump my 24 valve but idk how to go about it guve me some imput guys
Old Dec 2, 2011 | 02:12 PM
turbo2332's Avatar
pockets fairly deep?
Old Dec 2, 2011 | 05:37 PM
turbo20psi's Avatar
The kit is 2,000.00 or so you will need the cam sensor relocation bracket for the 2001-02 models.
You will have to buy a p-pump may be 1000.00 or more.
Got to have the injectors re-poped for the p-pump some work great some don't.
Old Dec 4, 2011 | 09:13 PM
ppump01's Avatar
1. about 3-5k depending on how big you wanna go
2. a weekend or two depending on your skills with a wrench
3. you have to want the most reliable truck on the street its totally worth it man
Old Dec 4, 2011 | 10:56 PM
01quadcab's Avatar
why do you want to p pump? a vp properly fueled will last a long time.
Old Dec 5, 2011 | 09:28 AM
00BRam's Avatar
I had maybe $1500 when all was said and done when I p-pumped mine. If you are patient and locate all the pieces you, most sourced from any 12v you can save a good bit that way. You can also find used untouched 160hp and 180 for around $600-800, which would be plenty for a street truck once they were modded. The cost is totally up to you and what you want.
Old Dec 14, 2011 | 10:08 AM
blackcoal's Avatar
ya x2 on this. search the classifieds for used parts
Old Dec 14, 2011 | 10:33 AM
MillerBoyzDiesel's Avatar
you need pump, pump gear, pump bracket, linkage, cam w/ retainer bolt, cam gear, front engine plate and cover, injection lines, injectors reworked, think thats everything. youll have to come up with a way to get oil supply to pump. Id try to get as much as possible from ebay, classifieds or salvage yard, if your lucky youll only have to buy lines and cam new but you can buy all of it new if you got the money
Nilson12
Sep 15, 2015 10:02 PM
HardLuck
Jun 24, 2015 08:04 AM
btg2820
Apr 27, 2015 12:09 AM
moneypitk5
Feb 12, 2015 11:01 AM
bonestock
Feb 1, 2015 08:41 PM
