sluggish start
Old Nov 28, 2011 | 09:02 PM
04dully6.0's Avatar
Default sluggish start
i have a 04 6.0 and when i start it it idels fine but when i start driving it seems as if it has no power but after a few minutes it runs fine. Its not throwing any codes, has a new ficm and new batteries. Im not sure if it could be sticky injectors?
Old Nov 29, 2011 | 08:13 AM
Mdub707's Avatar
Could be. I would still test the FICM, it's easy enough to do. A new one doesn't mean it wont fail again, it's not like the new one's have any more solder on the boards than the old one's, they all suck. You may want to try some Rev-X too.
Old Nov 29, 2011 | 09:39 AM
The hosser's Avatar
whats a good way to test the FICM?
Old Nov 29, 2011 | 09:44 AM
Mdub707's Avatar
Right at the top of the 6.0 page brother! https://www.dieselbombers.com/ford-p...procedure.html
Old Nov 29, 2011 | 11:44 AM
The hosser's Avatar
Thanks. thats a good write up...
Old Dec 3, 2011 | 11:02 AM
ryan6.7's Avatar
cold skip.. FICM would usually start losing voltage when it gets warm due to radiant heat.. only way i know u can check for a cold skip is to gain access to the injector plugs and unplug one at time while a buddy of urs puts a load on the engine.. Do this when its cold..
or if u hae a scanner that reads power balance.
Old Dec 3, 2011 | 11:12 AM
Mdub707's Avatar
If you have a scanner capable of reading power balance, typically you can just shut injectors off electronically without having to unplug them.
FWIW, I've seen FICM's work both ways, some work good cold, then lose power as it warms up, and I've seen some that are just terrible cold but work better the hotter the truck gets.
Old Dec 3, 2011 | 11:19 AM
ryan6.7's Avatar
i havent a scanner that does that. only the ford scanner ive seen.. and FICMs are very weird.. i just check voltage and diag from there.
Old Dec 3, 2011 | 04:15 PM
Mdub707's Avatar
Exactly, and even then they can still be bad. I have one right now that reads 48+V at all settings but the truck runs like complete garbage until it's up to full operating temperature.
I'm pretty sure AutoEnginuity with the ehanced Ford bundle can shut injectors off, I'll have to check again.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
