Transfer Case
Old Nov 28, 2011 | 08:14 PM
kieron_kohlmann's Avatar
Default Transfer Case
What transfer cases come on these trucks? The tag is missing on mine. Thanks
Old Nov 28, 2011 | 08:48 PM
justanother92's Avatar
Should be a NP 205
Old Nov 28, 2011 | 10:13 PM
Rusty89Cummins's Avatar
yep and if its bolted to an auto tranny its got a 29 spline shaft and if its bolted to a getrag 5 speed then its got a 32 spline shaft.
Old Nov 29, 2011 | 11:19 AM
Thanks Guys!
The reason I ask is because when I go to pull it down into 4H I get a grinding noise. Any ideas?
Old Nov 29, 2011 | 03:08 PM
sweetv8s10's Avatar
If it goes all the way in I wouldnt worry about it because its a gear driven transfercase so they grind a little sometimes or at least all of them I have ever had do and sometimes they whine a little running down the highway but I wouldnt worry about it to much.
Old Nov 29, 2011 | 06:29 PM
No, I can't pull it in when its moving. If I'm stopped, it goes in just fine.
Old Nov 29, 2011 | 07:28 PM
tower_ofpower's Avatar
Hubs locked in? The NP 205 isn't a synchronized transfer case, unless the driven gear is spinning as fast as the drive gear it's going to grind.
Old Nov 29, 2011 | 08:35 PM
If I remember correctly from last winter, I could pull it in anytime. Its a shift on the fly transfer case, so shouldn't i be able to?
Old Nov 29, 2011 | 11:59 PM
jdbigblue12v's Avatar
i have had the same problem with mine but only difference is mine doesnt like to come out of 4 low and is it something to take note of that when im driving my t-case chatters until i push the shifter forward and it stops? maybe low fluid?
Old Nov 30, 2011 | 11:01 AM
I was under the impression that these weren't synchronized transfer cases, GM made a synchronized 205 briefly but ran into some sort of issue with them, only produced them for a year or two. Without the front end spinning you won't get the desired "shift on the fly" think of it as trying to rake your truck into first without pushing in the clutch. Hubs have to be locked, it's a gear driven transfer case. Can't cram two teeth into one groove , it's all gotta be spinning at the same speed. At low speeds can you pull it into gear with minimal grinding?
