possible new turbo
Old Nov 28, 2011 | 07:30 PM
jdbigblue12v's Avatar
Default possible new turbo
friend of mine has a 1999 24v and he is making some serious power but he only has the stock hx35 and he ordered a s3000 and wants to sell me his stock hx35 for 250$ and i willl take up on the offer but wondering if i should buy the complete turbo (waste gate, exh housing included) because i am not sure if it will bolt right up and is it going to make a difference or should i keep the H1C and do the 60mm upgrade? i also would like more turbo whistle but will i hear it?
thanks james
bump
Last edited by jdbigblue12v; Nov 28, 2011 at 07:30 PM. Reason: Automerged Doublepost
Old Nov 28, 2011 | 08:50 PM
turbo2332's Avatar
cant tell you all about the exact fit of the turbo swap but you will very much enjoy getting rid of your lagomatic H1C!!! way faster spool up
Old Nov 28, 2011 | 08:59 PM
big bad diesel 416's Avatar
Site Sponsor
yep that HX35 will blow the H1c out of the water and it bolts right up
Old Nov 28, 2011 | 09:51 PM
cummins4ever's Avatar
any difference on the down pipe?
Old Nov 28, 2011 | 10:47 PM
wow cant wait to bolt it up!! now this is least on my worries but is it gonna have a loud spool? it also has the gds 60mm upgrade done to it and a 16cm2 housing!!
was also thinking of running twins with the stock H1C and the hx35 but sounds like a catastrophic failure LOL
Old Nov 28, 2011 | 10:57 PM
Site Sponsor
not in stock form
Old Nov 29, 2011 | 12:45 AM
turbo2332's Avatar
dang. does he have the stock 12cm housing??? the big housing is going to hurt spool up noticably. upgrade is cool. is truck can just rev higher than yours (most likely) so the 16 was more or less wasn't as noticed. still better than your h1c. it will whistle with a open air filter. not the stock box though. take the ring out
Old Nov 29, 2011 | 12:40 PM
i have a cold air intake and i will take out the ring and im happier with the 16cm housing so its easier to keepthe EGT's in check
Old Nov 29, 2011 | 02:15 PM
turbo2332's Avatar
i never get over 950 with mine with a stock housing. try both if your buddy still has the factory one. if you dont have a god awful amount of fuel you wont get a 12 scary hot.
Old Nov 29, 2011 | 03:06 PM
Site Sponsor
i seen one glow at 2000
you will like the 12 better IMO i loved my 12 the 16 lagged to much the 12 lagged a little too as far as i was concerned
to my knowledge they made a 9cm on some trucks i would like to try one if i could find one
