starting problem
Old Nov 27, 2011 | 07:48 PM
kycummins34's Avatar
Default starting problem
truck does not want to start after being shut off for a short period of time. if it sits all night itll start right up. have to pull fuel line off back of injection pump turn key let fuel pump out put line back on then start it. replaced o rings on connector tubes put new filter system on it and still no luck not sure if the fass pump is goin out or wut the deal is. any ideas?
Old Nov 27, 2011 | 09:10 PM
RAW's Avatar
RAW
So essentially it doesn't start when the engine/pump is warm? If so, its a classic symptom of a failing injection pump. More specifically, a cracked diaphragm in the pump.
Old Dec 1, 2011 | 08:17 PM
problem solved doin away wit the pump and p pumpin it
Old Jan 12, 2012 | 04:29 PM
gfmccutc77's Avatar
Not familir with the term "p pump". What is that?? I'm asking cause I just replaced the vp44 in my 01. I still can't get the thing to start
Old Jan 12, 2012 | 04:37 PM
GuyWithA24Valve's Avatar
a P-pump is the Bosch P7100 injection pump used on the 94-98 12 valve cummins
Old Jan 12, 2012 | 06:53 PM
gfmccutc77's Avatar
Will those work in the 24valves??? I didn't think they were interchangeable??
Old Jan 12, 2012 | 07:59 PM
cerickson's Avatar
You can p-pump your 24 valve but prepare to spend alot of $$$$$$$$$$.
Old Jan 13, 2012 | 09:50 AM
gfmccutc77's Avatar
Well, that at least gives me another option if I keep having problems with the vp
Old Jan 13, 2012 | 11:29 AM
MillerBoyzDiesel's Avatar
Hell yeah!
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Jmohr52
Nov 2, 2014 08:55 PM
