Tire Size
Old Nov 27, 2011 | 11:43 AM
92 cummins's Avatar
Default Tire Size
Will 35/12.50 fit on my powestroke, I've got a 2.5in leveling kit. Any help would be appreciated
Old Nov 27, 2011 | 12:30 PM
Senior's Avatar
250 or 350, I don't know that it matters. They should. I had 35's on mine when I bought it, but they were worn to slicks. I have to assume they didn't rub cause the wells don't look like it.
Old Nov 27, 2011 | 02:57 PM
Mdub707's Avatar
I'm guessing you're talking about the 05 in your sig?
250's have smaller blocks in the rear than the 350's. With the 2.5" leveling kit up front you should be safe. Do you have a 350 or 250 though? A 2.5" leveling kit on a 250 will make the front end sit high, until you put the 350 blocks in it. Mine is 2.5" custom spacer up front which I made, and 350 rear blocks, running 315/70/17 no rubbing.
Old Nov 27, 2011 | 08:19 PM
92 cummins's Avatar
Yes mine is a 350, will rim size matter? My summer wheels are 20x9
Old Nov 27, 2011 | 08:33 PM
Senior's Avatar
You shouldn't have any issues. The x9 part works out better for 12.5 inch tires, they won't doughnut out as much as mine did on x8.
Old Nov 27, 2011 | 08:43 PM
92 cummins's Avatar
Alright sweet, thanks guys
Old Nov 28, 2011 | 07:30 AM
Mdub707's Avatar
Backspacing will matter more than anything, but you should be ok on your 05.
Old Nov 28, 2011 | 07:41 AM
ArcticFlyer's Avatar
I am running the 35-12.50's on stock 18" wheels on my 250 with no leveling blocks, and I have no rub either.
Old Nov 28, 2011 | 05:09 PM
92 cummins's Avatar
Thanks for the help guys, my 33/13.50 have finally worn out, and I found a deal on the 35's so I thought I would ask for all of your opinions
Old Nov 28, 2011 | 06:12 PM
Karls03's Avatar
Bottom line, backspace will dictate if you need more lift. I can get contact with a 6" lift and 35s on 16x10s out wheelin. Deeper backspace = less lift
salty4life
Aug 20, 2015 10:46 AM
B737 Capt
Jun 9, 2015 06:34 AM
dallasca
28
May 26, 2015 12:58 AM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
LikeTheFabric
Ford Powerstroke 2011-Up 6.7L
Mar 10, 2015 01:18 PM
