manual tranny problems
Old Nov 26, 2011 | 08:55 AM
turbolag's Avatar
Default manual tranny problems
Last night I was driving down the freeway when I lost 50 gear. When I stopped I come to realize that I had lost first second third fith and reverse when this happened I'd stop and check the fluids everything was normal transmission was not hot. Does anyone have any ideas of what is to be? I managed to get the truck home in fourth gear it never popped out of gear once so I have no idea what is going on
Old Nov 27, 2011 | 09:21 PM
alwazjeepin98's Avatar
counter shaft is broke i think. or main
seems weird u lost 5th bc its part of the input shaft.... idk have to think on it for a little bit. does it feel like it goes into gear or wont slide into postion?
Last edited by alwazjeepin98; Nov 27, 2011 at 09:21 PM. Reason: Automerged Doublepost
Old Nov 27, 2011 | 09:52 PM
turbolag's Avatar
oh no it goes into gear u can feel it plus it stays in positions just like normal but when u let the clutch out there is nothing. i think its a counter shaft too
Old Nov 28, 2011 | 02:28 PM
Cody Cummins's Avatar
Mine did the same when i twisted my mainshaft in half
Sent from my PG86100 using Tapatalk
Old Nov 28, 2011 | 03:21 PM
BarryB's Avatar
What they said, thats what it sounds like to me also. When I replaced my main shaft and input shaft in my 99. I bought all my stuff from anaheim gear. I think you can google them. They had everything I needed for my trans rebuild. gears, shafts bearing, you name.
Old Nov 28, 2011 | 09:44 PM
andrewpursley's Avatar
if you only have 4th that is direct which no torque passes through ur countershaft in 4th you couple input shaft straight to mainshaft, id say something with ur countershaft
Old Dec 11, 2011 | 07:59 PM
turbolag's Avatar
should i try and rebuild it myself or get a replacement? i found a detailed book for it online and kits that come with the special tool required. but im not sure if it will have what i need...
Old Dec 11, 2011 | 08:38 PM
luke46's Avatar
Ya just had exact same thing fixed on a buds truck helped him pull it apart. Stripped out mainshaft gear it's the first gear in and transfers the power to every other gear so fourth or direct will still work. was about 300+ in parts alone.
AHAAN
Jul 19, 2015 10:28 PM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
Ol Goat
Jan 22, 2015 02:16 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
corey352
94-98 7.3L Performance
Oct 22, 2014 10:58 AM
