6.5 not starting
Old Nov 27, 2011 | 04:18 PM
HK_JJ's Avatar
Default 6.5 not starting
ok so my 6.5L all of a sudden wont start. has half tank of diesel, i cracked the t valve and i get diesel coming out as well as i cracked off a few injectors and i get fuel while starting.
it seems to start when return line off injector pump is off, could the problem be a clogged return line/?
tomorrow im going blow out the return line and see what happens, but im reading that the pmd fails often on these
anyone have any thought on this?
Ok so i have put clear tubing on the return off the ip after blowing out the return wich when i was doing so i could hear the air in the filler neck slighly
Not air bubbles when i run the truck eith the clear tubing i have also ran the lp eith t open to see if its pumping which it is,
What should i check next iv spent over 3 grand into this since i bought it little over a month ago starting to think i bought a lemon
Easton18t
Jul 30, 2015 02:06 PM
petew
Jul 25, 2015 03:56 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Chevy6.5/2500hd
Jun 1, 2015 09:44 AM
bdemutis
Dec 7, 2014 01:36 AM
