93 cummins wont charge
Old Nov 25, 2011 | 09:30 PM
94cummin12v's Avatar
Default 93 cummins wont charge
i have put a new alternator on the truck but still only charging 11.23 volts. i also have no speedo is it possible the ecm in the driver fender is bad
Old Nov 25, 2011 | 09:45 PM
dnrcustoms's Avatar
sent ya a pm. sounds like ur pcm is gone. U can use a external voltage regulator. It must be a 5sp truck, cause if it was an auto. your o.d wouldnt work.
Old Nov 26, 2011 | 03:13 AM
sweetv8s10's Avatar
What about the crank sensor?
Old Nov 26, 2011 | 05:37 PM
dnrcustoms's Avatar
You can check the gap. But in my dealings its always been the pcm 5-1 to a crank sensor!
Old Nov 28, 2011 | 03:43 PM
sotomo's Avatar
yeea i had that same problem chekc your battery your terminals make sure your getting a good connection and check that voltage regulator cause thats what ended up being the problem for me
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
