Head Leak
Old Nov 25, 2011 | 12:52 PM
xX_CuMMiNs_Xx's Avatar
Default Head Leak
Ok, my truck is leaking water at the front corner passenger side of head, its not mixing with oil or nothin, just leaking a little bit out and dripping down block. it was like this when i bought it and i wanna fix it. the guy i bought it off of had the head off and replaced gasket. he used the same headbolts and im wondering if i change the headbolts out one by one would it hurt the gasket cuz i know once you pull the head off you cant use the same gasket. so if i carefully replace one by one would it mess it up? or what should i do with it. i cant afford headstuds or that would be done
Old Nov 25, 2011 | 01:09 PM
turbo2332's Avatar
you can replace studs 1 by one but it sounds like the gasket is already junk. retork the studs and see if you get lucky.
Old Nov 25, 2011 | 02:13 PM
you mean bolt? ill try it later im fixin to go to the junkyard and look for dodge treasures
Old Nov 25, 2011 | 06:54 PM
turbo2332's Avatar
dodge treasures, good luck with that. hope you have a better yard than we do. and stud; bolt similar thing.
Old Nov 25, 2011 | 11:33 PM
haha. no twelve valves but they just got a built 24v in ive been gettin stuff off of. tow mirrors intake. and i didnt make it back home til now went to a party hung out with some friends. ill get on it first thing in the morning and post what happens. i think the head needs leveled possibly
Old Nov 26, 2011 | 01:07 AM
daveO's Avatar
That's a possibility. The heads are known to warp on these trucks, so if the previous owner didn't have the head decked, that might be the problem. Could also just need to be torqued. Head bolts require a few re-torques after some heat cycles.
Old Nov 29, 2011 | 10:32 AM
that was it!!! cured. it needed re torqued
Old Nov 29, 2011 | 10:41 AM
H.R.C.'s Avatar
the same thing happened to my truck and the sad part is that i work for cummins and have all the parts and still havnt fixed it.
Old Nov 29, 2011 | 11:02 AM
ive let mine leak for 3 months and i just didnt worry with it til now i decided to do it
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
ash23k
Dec 30, 2014 08:31 PM
Oct 31, 2014 08:10 AM
