a/c hoses
Old Nov 24, 2011 | 03:00 PM
Billy D's Avatar
Default a/c hoses
My a/c lines are freezing. It's 50 in Ohio, I haven't used my a/c fer over a month. It's like the compressor is kicking on, but I'm using the heater now. It all thaws off after I shut the truck off, but somethings wrong. What can it be Any info is greatly appreciated
Old Nov 24, 2011 | 03:33 PM
Dallas Flywheels's Avatar
The A/C with cut in on defrost mode..
Should read WILL cut in on defrost mode..
Last edited by Dallas Flywheels; Nov 24, 2011 at 03:33 PM. Reason: Automerged Doublepost
Old Nov 24, 2011 | 08:10 PM
Billy D's Avatar
The lines freeze if the heats on or not, defrost, heater, vent, I do have heat. Also i can feel my Evap inside the cab, under the dash, its very cold. It's not supposed to be like that right
Old Nov 25, 2011 | 09:46 AM
You say it is like the compressor is kicking in, Have you checked to see if it is running when it should not be? Maybe A/C relay is stuck. Pull electrical plug off compressor and run.
Old Nov 26, 2011 | 10:08 AM
Billy D's Avatar
Why does this happen? Is there something I can do, or just unplug it as said
Can I just pull the relay, or the fuse instead of unplugging the compressor
Maclain Marsh
Jul 13, 2015 06:23 PM
Jladanyi
Jul 4, 2015 02:43 PM
joldfield
Jun 22, 2015 04:27 PM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
JasonG.
Ford Powerstroke 08-10 6.4L
Feb 26, 2015 08:51 PM
