Input shaft removal on a getrag
Old Nov 24, 2011 | 10:54 AM
hiboy_76's Avatar
Question Input shaft removal on a getrag
How do i get the input shaft out of the getrag? Is there a little snap ring or something inside? I thought it would just slide out when i took the candle stick (front bearing retainer) off. I just dont wanna tear anything up worse than it is.
Old Nov 24, 2011 | 11:17 AM
BIGREDGOAT's Avatar
You gotta remove the topof the tranny, take the back case off and pull the man shaft up and the input will pop up with the main shaft.
Old Nov 28, 2011 | 12:39 PM
hiboy_76's Avatar
I was told if you get the gears lined up it'll just slide right out?
Old Nov 28, 2011 | 07:24 PM
big bad diesel 416's Avatar
Site Sponsor
line up the flat spot theres 4 flat teeth
http://www.dieselpowernetwork.net/Ge...360-manual.pdf
ur welcome
Old Nov 29, 2011 | 11:47 AM
hiboy_76's Avatar
ur welcome
THANK YOU!!!
BBD, i need to get ahold of ya about sending my pump off to ya and get that hot rod tune
Old Nov 29, 2011 | 03:03 PM
Site Sponsor
bring it on man!
woodsman27
Dec 9, 2014 09:55 AM
SMatyac
Nov 15, 2014 07:35 PM
