1996 6.5L K3500 limp mode
Old Nov 22, 2011 | 10:26 PM
Chevyguy92's Avatar
Default 1996 6.5L K3500 limp mode
My 1996 6.5L K3500 goes into limp mode between 70-80mph. ses light come on sometimes but I have no communication with my PCM. If I restart the truck i'm good till I get to 70-80mph again. I checked all the wires at the ALDL port an I have all my hots and grounds. What should I check next?
Old Nov 25, 2011 | 06:56 PM
Hartford59's Avatar
how much boost are you pushing? my old 6.5 would go into limp mode before i put a chip in it.
Old Nov 25, 2011 | 11:18 PM
Chevyguy92's Avatar
I'm not sure how much boost it is. I'm running the turbo master kit from Heath diesel and the spring measures 2". Should I tighten it or loosen it?
Old Nov 26, 2011 | 08:56 PM
Hartford59's Avatar
get a chip. i think your pushing to much boost for the stock computer. mine did the same thing. or let off the boost some. But the computer says its running to much and things the waste gate is stuck closed, and that makes it go into limp mode.
Old Nov 27, 2011 | 09:14 PM
Chevyguy92's Avatar
Okay thanks I turned the boost down now its not going into limp mode it must have been making the truck run to lean which caused it to go into limp mode. I guess the problem with the scanner not reading the computer is a different issue.
Gm3500
May 7, 2015 11:01 AM
ClintD.
Chevy/GMC Duramax 06-07 LBZ
Mar 23, 2015 04:37 AM
syctaz
Mar 3, 2015 09:23 AM
To fast
Chevy/GMC Duramax 04.5-05 LLY
Feb 10, 2015 09:30 AM
Brandanllewellyn
Oct 20, 2014 08:09 PM
