98.5 cummins charging problem?
Old Nov 22, 2011 | 06:20 PM
98dodgecummins's Avatar
Default 98.5 cummins charging problem?
One of my friends has a 98.5 dodge cummins and when he very first starts his truck up the volts are low buy when he drives it about 10 minutes the volts are normal what could this be? Batteries or Alternator? possibly?
Old Nov 22, 2011 | 08:34 PM
RAW's Avatar
RAW
Maybe have a read over this thread:
https://www.dieselbombers.com/24-val...batteries.html
Old Nov 22, 2011 | 08:44 PM
01quadcab's Avatar
grid heater
Old Nov 22, 2011 | 09:12 PM
RAW's Avatar
RAW
Grid heaters pull up to 200 amps at a time, and cycle after the engine is run. If he notices the lights dim, engine grunt a little, that's the grid heaters running.
Old Nov 22, 2011 | 10:33 PM
lunk's Avatar
ya its normal grid heater sucks alot of juice takes time to recover after start up
Old Nov 23, 2011 | 07:17 PM
72fj's Avatar
Default slow charging after start up?
could be the pcm,voltage reulator runs thue computer,my 02,sometimes has same systems even w/new alternator,battery cables,optima red top batts.i did work on a 98 earlyer this year truck had simalar symtems and it was the pcm,i would fully charge batteries and load test em,clean cables and grounds,hope this helps,have a great turkey day!!!!
burndiesel
10
Feb 7, 2023 01:15 AM
Jordon92
Dec 14, 2015 01:37 PM
jeremy01995
Sep 14, 2015 06:34 PM
gd1996
For Sale
May 15, 2015 09:42 AM
97boatstroke
Dec 22, 2014 09:54 PM
