Strong smell of diesel after you get on it...
Old Nov 22, 2011 | 02:03 PM
wilde6.0's Avatar
Default Strong smell of diesel after you get on it...
I've noticed here recently that if I get in it pretty hard, by the time I come to a stop, I my windows are down I can smell diesel very strongly, maybe it's just me, just thought I'd see what y'all would say.
And I have yet to delete the muffler and cat.
Old Nov 22, 2011 | 02:38 PM
Mdub707's Avatar
Deleting the muffler or cat should have no effect.
It smells like fumes or raw fuel? My guess without more info would be cracked up-pipe. Try reading the thread at the top of the page for the new guys, then repost with more info.
Thanks, and welcome to DB.
Old Nov 22, 2011 | 03:07 PM
wilde6.0's Avatar
Yes sir, that's exactly what it smells like, I me
An the truck is bone stock, and not necessarily when I get kn it hard, just mainly when it boosts any higher than 10-15 lbs of boost. If I'm not mistaken, the up pipe is what connects the passenger manifold to the y pipe into the turbo?
Old Nov 22, 2011 | 03:26 PM
Mdub707's Avatar
Well technically there are two up-pipes. Each one connects an exhaust manifold to the y-pipe (collector) up top. The passenger side is a solid unit though, the drivers side has the EGR cooler mounted to it, and it has a bellowed section. That bellow section is typically what cracks. If you have to go in that far to swap it, I would highly recommend just doing a full EGR delete at this point, it will probably cost the same, if not cheaper, and you're already all the way in there, and it will only increase reliability.
Ever get any strange high pitch noises when you first fire it up or anything?
Old Nov 22, 2011 | 05:40 PM
wilde6.0's Avatar
No high pitch noises at all, I'm going to talk to my local dealership tomorrow and ask what all is covered in warranty, cause if it wSnt for that it'd already have an EGR delete kit on it. I mean it seems to be running fine, no noticeable power loss, just the strong smell of raw diesel.
Old Nov 22, 2011 | 07:28 PM
Mdub707's Avatar
Tell them you get a strong smell of fumes in the truck. If it's under warranty they should cover it. I had one covered under warranty before.
Old Nov 22, 2011 | 09:43 PM
LORDDiESEL's Avatar
Another great ford/IH screw up. The one on my non EGR side is toast.....again.
Old Nov 23, 2011 | 12:58 AM
ntmdtr3fan's Avatar
I had the raw fuel smell a few months ago. It ended up being the Oring for the fuel regulator.
Old Nov 26, 2011 | 10:43 AM
wilde6.0's Avatar
i may have to check the fuel regulator, and as far as warranty, its covered if its the up pipe, either side. and as soon as i mentioned "EGR delete kit" they were like whoa! that will deff void your warranty, even a cold air intake will apparently void it as well.
Old Nov 26, 2011 | 05:13 PM
ntmdtr3fan's Avatar
If your still under warranty then the Oring on the fuel regulator is covered. had mine fixed a few months ago and it was covered.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
tbreddiesel
Contests And Give Aways
Jul 21, 2015 07:28 AM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
