94 head lights randomly turn off!
Old Nov 20, 2011 | 05:18 AM
PStroker's Avatar
help 94 head lights randomly turn off!
At random my headlights will flash off and then come back on a couple seconds later, it seems to happen sooner if i run the brights. Its only the headlights. The amber blinker lights stay on. Its starting to scare me cause where i live there are deer everywhere and i dont want to buy a new bumper yet. Any info helps!
Thanks,
Spencer
Old Nov 20, 2011 | 08:48 AM
Dallas Flywheels's Avatar
Headlight relay weak.
Old Nov 20, 2011 | 10:56 AM
Whit's Avatar
Site Mascot
yes............plug in a new relay
Old Nov 20, 2011 | 02:18 PM
daveO's Avatar
Didn't think the 2nd gens used headlight relays. That's why so many people have problems with the switch. I know my 98 didn't have any until I put them in.
Old Nov 21, 2011 | 04:55 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 on the headlight switch! Not sure about the relays... It would make a lot of sense why they always go bad tho
Old Dec 4, 2011 | 02:58 AM
BramanteCummins's Avatar
its the switch, i had mine melt down plowing when i forgot to shut off the headlights. on older trucks the contacts build up dirt and grime making more resistance in the switch. have fun wiring the new one!
Old Dec 4, 2011 | 01:44 PM
keithduke01's Avatar
Some truck owners actually took their trucks into dodge to have the headlight switch recall fixed which was to add a relay to the circuit to keep from melting the switch plug and possible fire, so if you remove your dash and find a relay added into the harness that plugs into the switch, replace the relay first, then the switch if that doesnt fix it. If you dont find the relay, contact your local dodge dealership and have the recall completed and you shouldnt have to pay for the switch that burnt up.
Old Dec 4, 2011 | 06:59 PM
gyayo2012's Avatar
The recall is only for 3500, i called and tryed getting it done but they will not since it is a 2500 the kit coast 130 bux easy to install sux that you have to pay for it tho...!
Old Dec 4, 2011 | 08:01 PM
senotext's Avatar
mine did the same thing last week and i took it apart the connector at the headlight switch was melted
Old Dec 6, 2011 | 01:02 PM
1AMatt's Avatar
A friend of mine had one go bad and it fries the whole headlight wiring harness No all his lights are on toggle witches
