5x12 injctors, dana 60 and 70 parts
Old Nov 19, 2011 | 11:50 PM
cumminspwr11's Avatar
Default 5x12 injctors, dana 60 and 70 parts
i have a set of 5x12 injectors for a 12valve, $350 plus 6 good cores, they are only about a year old, pop tested and are in great condition also are the correct spray patteren
dana parts are
d70 ring and pinion matched 3.54 gear ratio-$65 plus shipping
d60 posi carrier-$150
d60 open carrier 4.10 and up gears $30
d70 open carrier $30
ford dana 60 spindles off 97 and older axle, $70
1410 and 1350 yokes $35 each
all prices are OBO and plus shipping
Old Nov 20, 2011 | 08:55 PM
cummin_un_glued's Avatar
FormerVendor
on the d60 open carrier you say 4.10 and up so its the same as the 3.55 or not?
Old Nov 21, 2011 | 04:14 PM
im pretty sure its for 4.10 and numerically high gears, because i also have a few carriers that had 3.55s on them and they are two different carriers and from what i can find on google this one i have is for the lower gearing
Old Nov 21, 2011 | 07:55 PM
Mark Nixon's Avatar
Dana 60 and 70 are both 3.54 and 4.10 carriers.
Dana 80 is 4.10 up OR 3.54 only.
Mark.
Old Nov 21, 2011 | 11:19 PM
FormerVendor
so that carrier wouldnt work for 4.56 to 6.17 gears then
Old Nov 26, 2011 | 06:22 PM
according to him no, but i found a web page that states that the part the ring bolts to is thinner on the 4.10, 4.65 carriers than it is on the 3.54 carriers and i can see without measuring that there is a difference in my two carriers, maybe i can find some exact measurements and determine for sure what it will work with,
its a d60 open carrier out of a sport 2500 dodge truck that had stock 4.10 gears
Old Nov 26, 2011 | 06:26 PM
Red_Rattler's Avatar
High Tech Redneck
You can slam anything into a D60
Old Nov 26, 2011 | 06:37 PM
FormerVendor
ok then it wouldnt work for what i need, thanks tho
Old Nov 27, 2011 | 11:42 PM
dmaxkiller's Avatar
whos 5x12s?
Old Dec 1, 2011 | 12:29 AM
a guy out of texas, not sure on the company name but they were brand new and are the correct spray for our 12vs, i swat 370s for these 5x12s and love them over those 370s
