change ignition tumbler
Old Nov 19, 2011 | 06:43 PM
css89's Avatar
Default change ignition tumbler
I have 89 6.2 anyhow lost keys could be grandson not sure but how do I take tumbler out so I can put in new key set
Do I have to take steering wheel off or is there another way
Old Nov 19, 2011 | 07:54 PM
wildbill's Avatar
You'll have to remove the steering wheel. Then the lock plate, which you need a tool to press it down to remove a snap ring. Once that's out of the way, a few screws to remove the turn signal cam/switch. Then a T30 torx bit to remove the lock screw, and out comes the tumbler.
Old Nov 20, 2011 | 10:37 AM
css89's Avatar
Default ignition
Thanks I was afraid that would be the answer. not like the old ford. will have to see if I can find the steering wheel puller again
wlofton
11
Jun 26, 2018 08:58 AM
ctjkelley
Jun 3, 2015 06:01 AM
david.burger
May 30, 2015 08:25 AM
crusty
5.9L CR Performance
Apr 26, 2015 03:31 PM
Mar 13, 2015 09:20 AM
