Loss of oil pressure while driving
Old Nov 17, 2011 | 11:34 PM
donmega182's Avatar
Default Loss of oil pressure while driving
My 2005 6.0 power stroke oil pressure gauge dumps and then the idiot light comes on and shows low oil pressure. Checked the oil level, that's good. Talked to a mechanic and he wants to charge me a TON of money. I am mechanically inclined but never worked on a diesel. Is this a pump? HPOP? pressure switch? Help!!!!!!!!!!
Old Nov 18, 2011 | 05:28 AM
Mdub707's Avatar
What type of oil filter and oil filter cap are you using? My guess is some sort of filter that uses it's own style cap? If so, switch back to a motorcraft filter and cap immediately. HPOP typically works or it doesn't, it wouldn't cut in/out. If your HPOP wasn't working the truck wouldn't start. You could have a high pressure oil leak though. As the oil heats up, it thins out and makes it harder to maintain pressure. Do you have access to a scanner? Sounds like you've got a mechanic who's ready to take your money without diagnosing anything.
Old Nov 18, 2011 | 07:31 PM
donmega182's Avatar
I am using Motorcraft, my thoughts were the same on the mechanic. Just changed my oil and filter 2 weeks ago. Crazy thing is the truck doesn't run funny or anything out of the normal. I'll plug it in and see what codes are popping up. Thanks a bunch!
Old Nov 18, 2011 | 07:40 PM
Mdub707's Avatar
If you have an actual scanner, try measuring actual ICP vs. desired ICP and check IPR duty cycle if you can and let us know.
Old Nov 19, 2011 | 05:53 PM
donmega182's Avatar
I ran a scanner through the truck and it did not come up with any codes. Maybe just a sending unit issue for the gauge?
Old Nov 20, 2011 | 07:22 AM
bismic1's Avatar
If you don't have any performance issues, it very well could be the oil pressure switch (unfortunately it isn't an actual pressure gauge).
As Mdub707 said a scan tool (like the scangaugeII) will enable you to pull engine operational information - like the ICP (HPOP discharge pressure) and the IPR regulator duty cycle (the IPR is the control valve for the high pressure oil pressure regulation).
You won't find oil pressure w/ these tools for the reason I mentioned earlier.
Old Nov 21, 2011 | 08:17 AM
Mdub707's Avatar
Yeah you need a physical scanner, not just a code reader. Going to be nearly impossible to diagnose this one without the scanner. Where are you located?
Old Nov 22, 2011 | 01:16 AM
donmega182's Avatar
I am in Vancouver Wa. and I have been reading as much as I can about scanners but everyone claims to be the best in these devices. Any tips on a scanner?
Old Nov 22, 2011 | 08:10 AM
Mdub707's Avatar
If you already have a labtop get Autoenginuity with the enhanced Ford bundle, should be able to get it for about $350, IF you already have a labtop to use it on.
Durtyd09
Nov 11, 2015 01:43 PM
Bighouse
Apr 9, 2015 06:51 PM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
