Growling noise while turning.
Old Nov 17, 2011 | 07:02 PM
6BTPower's Avatar
Default Growling noise while turning.
My truck has developed a growling/loose sound in the front end while turning. It doesn't matter which direction I turn. It's more noticeable at slower speeds. I just had a front end alignment done and was told everything looked good. I've spent half an hour poking around under there and can't find anything. Any ideas? Thanks!
Old Nov 17, 2011 | 10:34 PM
tiremann9669's Avatar
Did you check the U joints in the front axles ?
Old Nov 17, 2011 | 10:53 PM
Red_Rattler's Avatar
High Tech Redneck
wheel bearings possible
Old Nov 18, 2011 | 05:19 AM
6BTPower's Avatar
New ujoints. I'll check the bearings out. Don't you have to replace the whole hub if that's the case?
Old Nov 18, 2011 | 07:58 AM
High Tech Redneck
Yes you do... Just jack the truck high enough to get a pry or cheater bar under the tire and pull up. If it's bad you'll feel and see it.
Old Nov 18, 2011 | 02:42 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Yes I would say a wheel bearing too
Old Nov 18, 2011 | 10:33 PM
6BTPower's Avatar
Ok thanks guys. Sounds like that's the most likely culprit. I'll check them for play on my next day off. Do you all think I should avoid driving it anymore until I fix it? I have another rig I can use if I have to so it's not the end of the world. I hear these unit bearings can be spendy. Who's the best place to buy/order replacements from? I want to be cost conscious, but not to the point of buying junk. Thanks!
Old Nov 21, 2011 | 11:00 AM
6BTPower's Avatar
Well guys, I dunno what to think now. I checked both front hub bearings and they are each tight as a drum, no play at all. So I took it out for a spin for the first time in 4 days, and couldn't get it to make any noise. No clue what that was all about. I guess I'll just drive it and see if it comes back.
Old Nov 21, 2011 | 05:38 PM
1AMatt's Avatar
Its a Dodge.... It will come back
Old Nov 21, 2011 | 05:42 PM
6BTPower's Avatar
LOL I know right! I have the characteristic "shock clunk" that I need to address also, but this noise was different. I'll just drive it and be happy util it returns .
