gauge, vp or something else
Old Nov 16, 2011 | 09:41 PM
Nutty Jeeps's Avatar
Default gauge, vp or something else
So on my way to work today i all of a sudden noticed my fuel pressure gauge said 0 , truck was running fine and has been running fine. I got to work gauge sat on 0 when idleing waiting for egts to go down, so i fired it back up and it was bouncing around between 0-10 after it sat an idled for a bit it sat on 0. After work it bounced around while she was warming up soon as i took off down to 0 and stayed there until I got home sat at 0 till I turned my truck off and back on then did the same thing with the bouncing really LOW. Got out the good ole smarty checked codes showed P0122 Throttle position sensor voltage low. What does that have to do with my fuel PSI? first time i had this code.
Anyways truck doesn't act like its starved of fuel. Still blows black when I get on it, has the same throttle response and all. Running the same all around as it was before I noticed the fuel psi. Have videos im uploading to youtube right now to put on here. Fuel pressure gauge is auto meter and only about 3-4 months old probably not even that old. Fuel PSI is normally about 17-18 idle. Any input would be great and why do i have a throttle position sensor code with this problem....
just went to start it again gauge stayed on 0 and didn't move. The lights are working on it thought but thats it. I'm thinking its the gauge somewhere... kinda cold to screw with it outside at 9:30
Last edited by Nutty Jeeps; Nov 16, 2011 at 09:41 PM. Reason: Automerged Doublepost
RAW's Avatar
RAW
What type of gauge is it? Make, model, electric or mechanical. Have a snubber?
Old Nov 16, 2011 | 09:44 PM
it is an autometer factory match for my year, not sure if its elec or mech, diesel shop ordered it and put it in. I just told them what I wanted for brand... I'll see if it says on my receipt
Old Nov 16, 2011 | 09:52 PM
RAW's Avatar
RAW
Due to pulsations from the VP, a snubber is required to smooth out the force. Without one, gauges die.
Old Nov 16, 2011 | 09:54 PM
what does the snubber look like?
Old Nov 16, 2011 | 09:57 PM
RAW's Avatar
RAW
About like that.
I'm not saying buy from these guys, but here is a site that has a picture and description of one.:
Beans Diesel Performance - Auto Meter Fuel Pressure Snubber Restrictor (Powered by CubeCart)
Old Nov 16, 2011 | 10:06 PM
I think theres one on there found my receipt 8560 autometer sport comp fuel psi gauge kit 24 valve dodge 0-30 psi electric transducer
thats what my bill says
Old Nov 16, 2011 | 10:11 PM
RAW's Avatar
RAW
This one:
Auto Meter
I sure hope they put the snubber in. It could be electrical issues as well. A loose wire, blow fuse, broken wire, even bad connectors at the gauge or sender.
Old Nov 16, 2011 | 10:16 PM
The gauge is exactly three months old today.
and yep that'd be the gauge
Last edited by Nutty Jeeps; Nov 16, 2011 at 10:16 PM. Reason: Automerged Doublepost
Old Nov 16, 2011 | 10:18 PM
RAW's Avatar
RAW
Unfortunately, time doesn't mean much. I've seen parts last decades, and I've seen them fail in seconds.
It sounds like you still have good fuel pressure, but I wouldn't bet my $1000+ injection pump has good fuel pressure because there is a cloud of black behind me. If you can, get another gauge on there to confirm you have good pressure. Maybe take it back to the place that installed it, and see if you can get some warranty out of them. If not, hopefully they can find the problem.
