Torque Converter Lockup
Old Nov 16, 2011 | 07:44 PM
colinheitshusen's Avatar
Default Torque Converter Lockup
Ok, got a quick question. Whats a lockup do,and what are the advantages and disadvantages.
Old Nov 16, 2011 | 08:01 PM
empty wallet's Avatar
Are you asking about a lock-up switch?
Old Nov 16, 2011 | 08:05 PM
dieseldude848's Avatar
its almost like having a manual trans. when the switch is flicked it locks up the converter so theres no slip in the drivetrain.
Old Nov 16, 2011 | 09:26 PM
RAW's Avatar
RAW
Advantages include better engine braking by keeping the RPM's higher while slowing down. I like to keep mine on while pulling a trailer to reduce transmission temperatures. If your around town, the T/C may lock and unlock a lot while driving around, locking it makes for a smoother ride.
Just don't forget about it while getting to slow speeds. It will stall the engine.
Old Nov 16, 2011 | 09:35 PM
So does it basically hold it in the certain gear you want?
Old Nov 16, 2011 | 09:39 PM
RAW's Avatar
RAW
You can lock it in 3rd of 4th with stock electronics and stock valve body. It will stay locked in 3rd if you have O/D off, and the lock up switch engaged. It will not down shift. With the O/D off button not turned on, it can shift up into O/D. It will not shift out of this gear as long as the switch is on. You can physically downshift to 2nd to make it go into 2nd with the lock up switch on. Same for 1st.
Old Nov 16, 2011 | 10:01 PM
sweet thanks! im wanting to upgrade my auto as soon as money allows. ill have to add one of these to the list.
That's weird mine locks up in 2nd
Old Nov 16, 2011 | 10:04 PM
RAW's Avatar
RAW
With a stock valve body, and stock electronics? I have a stock VB, and just the switch. I can't lock up in second.
Old Nov 16, 2011 | 10:12 PM
All you need is a toggle switch, wire, and a t connector. At Any automotive store. About 15-20 bucks
Not sure if the tranny is stock. Don't know much on the previous history because I bought it at a local auction but yeah it does lock up in 2nd so what would cause that to happen? Valve body or electronics?
Last edited by dieseldude848; Nov 16, 2011 at 10:12 PM. Reason: Automerged Doublepost
