Loss of power, high EGT
Old Nov 15, 2011 | 03:52 PM
SMITTYJT's Avatar
Default Loss of power, high EGT
I've owned this truck for a while and have noticed a loss in HP over the last year while the exhaust temps averaging around 800 just going down the road with little to 10 psi of boost.
I have not seen any temp over 1200 degrees while towing but can't figure while I am running so high normally. I recall it normally running around 600 degrees on pyro while just driving but am wondering if I am getting a poor spray pattern on an injector or dripping injector. I am running the Superchip @ tow/haul under weight setting and I have not noticed any significant black smoke in mirror. Any suggestions? Thanks!
Fuel mileage has also dropped but not all the time, I used to get 20-22 mpg now more like 17-18 mpg, sometimes I get 19mpg. Fuel pressure is 16-18psi @ idle and 8-10psi WOT. Little difference I know but I notice w/ fuel @ $4.00+ a gallon. Have not changed the fuel filter in 15k fyi may contribute but doesn't explaing high EGT. Any help is greatly appreciated.
Old Nov 15, 2011 | 06:08 PM
wyodiesel92's Avatar
Might have a boost leak. Makes higher egts and could lower fuel economy. Change that filter first
Old Nov 21, 2011 | 03:57 PM
SMITTYJT's Avatar
Replaced fuel filter, ran one tank and have constant boost pressure with no bleeding, fuel mileage is the same, crappy! Thanks wyodiesel92, I had a buddy verify and help make sure that was good. I am thinking of having a pop test done and see where I am at on the injectors. Any other thoughts?
Old Nov 22, 2011 | 03:55 AM
That'd be my nextstep pop testing injectors
wiremanWelder357
May 25, 2015 09:10 PM
robbyS
Apr 16, 2015 02:22 PM
Bighouse
Apr 9, 2015 06:51 PM
krg3590
Mar 15, 2015 08:57 AM
