Drivability with 13mm
Old Nov 15, 2011 | 11:03 AM
CumminsKid6's Avatar
Default Drivability with 13mm
How much power and dd change would a 13mm injection pump make.
Old Nov 15, 2011 | 06:47 PM
monster12valve's Avatar
dd with a 13mm pump is gonna be a smokey hot ride. 12mm pump will make a ton of HP. 800hp on a benched 12mm is do able.
Old Nov 15, 2011 | 11:06 PM
Next question would be what all is done to ip when they are benched. Obviously they are made better and fuel flow would have to be better. But is there any specifics to it to what is actually done
Old Nov 16, 2011 | 06:20 AM
turbo2332's Avatar
totally depents on how you want the pump set up? cam profiles cc's dv's springs, timing
Old Nov 16, 2011 | 01:21 PM
dipapadakis's Avatar
where is a good place to get it benched? how much does it cost also?
Old Nov 16, 2011 | 08:00 PM
scheid, columbus diesel, heisley machine to name a few.
Old Nov 17, 2011 | 06:26 AM
12vcummins96's Avatar
you can get a pump benched and set up with 5k gsk for 600 bucks or so
