Head light switch?......
Old Nov 14, 2011 | 07:48 PM
gyayo2012's Avatar
Default Head light switch?......
well heres my problem... i was riding around the other day, my parking lights, front, rear and marker lights stoped working... but my head lights, brake lights, 4ways, and blinkers work great.. Ive been reading that these trucks have a problem with the head light switches... btw looks fine! have been chacing the harness all day and everything looks to be just fine all the fuses are fine idk what else to do?!! ..............................................has anyone had this isue b4?
Old Nov 15, 2011 | 09:43 AM
Pyro690's Avatar
Check the fuse under the hood?
Old Nov 15, 2011 | 09:51 AM
There was a recall on some of the switches. I will see if I can find it for you.
Old Nov 15, 2011 | 10:26 AM
gyayo2012's Avatar
yeah there was a recall on only the 3500's for 96 i believe!! and yes the fuse under the hood is good! there all goood im stumped!
Old Nov 15, 2011 | 11:07 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Yep these tend to go bad. A friend burnt up his whole headlight wiring harness not fun
Old Nov 15, 2011 | 12:33 PM
gyayo2012's Avatar
think im goin to have to hitup the junk yard for this one! let ya'll know how i make out
Old Dec 13, 2011 | 06:39 PM
gyayo2012's Avatar
well for some reason my markers and everything started to work!! but every once in a while its pops a fuse and wont work again.... then it will work again for another week or so and do it all over again!!! idk what the deal is with this thing no cut wires no burned wire cant find anything grounding out! new switch what could be the issue here??
Old Dec 13, 2011 | 11:32 PM
Craig Ducharme's Avatar
Just had the same thing happen to me today, Fuse popped. No reason. Changed the fuse in the cab on the drivers side at the door panel and all is good again. Switch?
Old Dec 14, 2011 | 12:11 PM
Sorry I forgot about this...look here:
Recall 819
Old Dec 15, 2011 | 03:03 PM
gyayo2012's Avatar
well just got back from the junk yard took a switch out of a 94 gas job put it in and **** sure enough it works!!! all the time now i can push and pull untill my fingers cramp and i havent blown a fuse yet!! im still goin to go to the dealler and grab the harness that "takes care of the problem" because im sick of putting switches in im just glad its only poping fuses and not frieing wires!!!
