smoke screw on p pump???
Old Nov 14, 2011 | 03:42 PM
Hartford59's Avatar
Default smoke screw on p pump???
I didnt know there was a smoke screw on a p pump? where is it? i have already got a 0 fuel plate and the star wheel. what else is there to do inside the pump? i thought i got it all?
Old Nov 14, 2011 | 04:19 PM
Sudia247's Avatar
The smoke screw is covered by a cap on the back side of the AFC. takes two screws to remove the cover.
Old Nov 14, 2011 | 04:31 PM
Hartford59's Avatar
so do i have to take off the cap that the fuel plate is under?
Old Nov 14, 2011 | 04:33 PM
gyayo2012's Avatar
http://www.cumminsforum.com/forum/94...explained.html
that might help you a bit..
Old Nov 14, 2011 | 05:00 PM
Hartford59's Avatar
does it get screwed in or out?
Old Nov 14, 2011 | 06:12 PM
Red_Rattler's Avatar
High Tech Redneck
In and this should help you... But all it will do it add fuel down low making egts hotter and possibly making it take longer to spool... Didn't mess with mine
https://www.dieselbombers.com/show-t...-p-pump-4.html
Old Nov 14, 2011 | 07:53 PM
gyayo2012's Avatar
what do you gain by grinding the foot? did you adjust the sprocket? I recently put a plate in and have been dien to play with the afc just didnt know what to do! ive worn out my search box looking for a thread like that!!!
one more thing... do you remember the part# for that bhaf!!??
Old Nov 14, 2011 | 07:59 PM
High Tech Redneck
More rack travel and yes loosened it up some but adjusted for full travel at 25 psi. When I get the truck on the track I may have to adjust it accordingly
Old Nov 14, 2011 | 08:03 PM
High Tech Redneck
Here is a cross referenced list:
BHAF numbers
NAPA # 2790
Fleet Guard # AH19037
John Deere # PMAH19037
Wix # 42790
AFE # 20-40044
Hastings AF 1012
Carquest # 87790
Caterpillar 3i 0005
Fram CA 6818
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
Texasboy
Sep 10, 2015 07:44 AM
Fred427
Jun 29, 2015 09:43 AM
HardLuck
Jun 24, 2015 08:04 AM
moneypitk5
Feb 12, 2015 11:01 AM
