head bolt problem
Old Nov 13, 2011 | 06:50 PM
Cummins90's Avatar
Default head bolt problem
hey guys thanks in advance for the help here.. well heres my problem. i blew my head gasket about a week ago. so i pull it all apart clean it all up and get ready to put it back together. every were i read and have been told is to run a tap thru the bolt hols to make sure they get the best clamp they can.. no problem. well if your me you us a 12x1.5 tap instead of a 12x1.75. how i pulled this off i dont know.... dont ask because i just plain screwed up. well now u prolly figured it out i cant bolt my head tight now cuz they just wanna pull the threads out. so i was woundering if i could tap it to a 1/2 bolt size and run 1/2 bolts instead of 12mm. would a grade 8 bolt hold up as a head bolt or no? or do i need to drill and tap to a 14mm and just stud it? im kindof on a budget here so the cheaper i can get it fixed right the better.. so lemme know your ideas... thanks a bunch guys
Old Nov 13, 2011 | 07:37 PM
crazy clem's Avatar
wow sorry man , a few things to consider. if you upsize the bolts are you going to have to drill out head also , will you hit critical passages etc. also torque specs are designed for certain sized bolts. believe it or not too much torque can be just as bad as not enough, eg at the same torque value a grade 8 will stretch less than a gr 5 which means different clamping force. maybe im overthinking it . hope someone with more experience has a solution for you. good luck
Old Nov 13, 2011 | 08:37 PM
Red_Rattler's Avatar
High Tech Redneck
Id go 14mm and stud it if it was mine...
Old Nov 13, 2011 | 09:22 PM
Cummins90's Avatar
well my buddie works at pure diesel power and said he can get me a used set of 14mm studs for like 100 bucks. they were only used for a short time in the shop on a motor. so im thinkin thats gonna be my best option.... do i have to get the head drilled out to fit the 14mm studs? any one have a rough estimate on how much that costs? should i get the head resurfaced while im at it?
Old Nov 13, 2011 | 09:48 PM
High Tech Redneck
You in wisco? If you have a bud there, take the head to them and tell them to have Joe do it and get it oringed while he has it...
Old Nov 14, 2011 | 01:50 AM
EasternAggie's Avatar
Dude this sucks, sounds like something that would happen to me. Best of luck to ya
Old Nov 14, 2011 | 09:02 AM
Cummins90's Avatar
yup. i live bout 20 min from there shop. dont really know many people there only been there once or twice. im gonna have my buddie shane bring it there. he can get it dont cheaper if he goesin on his own time for me... whats it cost to get it oringed?
burndiesel
10
Feb 7, 2023 01:15 AM
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
