edge chip
Old Nov 13, 2011 | 04:52 AM
globalwarmingcontributor's Avatar
Default edge chip
im looking at getting a edge ez for a 01 cummins, i own an 02 cummins, is there an adapter i would need to make this work on my truck?
thanks in advance
Old Nov 13, 2011 | 09:08 AM
RAW's Avatar
RAW
The EZ should work just fine. Only thing that may need an adapter is the MAP sensor plug. There are 3 different styles. Depending on which one is on your truck determines which adapter you need.
After that has been said, why an EZ? If you already have gauges, why not a Comp? Way more power, and bang for your buck!
Old Nov 13, 2011 | 12:15 PM
Oil Igniter's Avatar
I just got the Edge comp and its great. Seemed to be one of the best for the money and the instal was super easy. It was as if the truck had been constipated and now it ***** and gits.
Old Nov 13, 2011 | 12:48 PM
Get the Comp
Luke
Old Nov 13, 2011 | 12:58 PM
flyhunter's Avatar
I don't know about the Comp. I've talked to several people that have had VP failures after tapping the pump wire.
Old Nov 13, 2011 | 01:06 PM
RAW's Avatar
RAW
That will happen if you have a weak pump already, or if you have poor fuel supply.
Old Nov 14, 2011 | 11:13 AM
vcustoms86's Avatar
X2 on the weak pump and/or low fuel pressure. 24v's need a good lift pump added before any HP dreams start.
Old Nov 14, 2011 | 06:29 PM
well im adding a fass 95 series pump to the rig.... i heard about vp failing as well. but reason it failed was because of weak lift pump. im not sure i can afford the comp. unless i can get rid of my superchips flashpaq. maybe ill put that up for sale.
Old Nov 16, 2011 | 10:16 AM
vcustoms86's Avatar
I would. The Comp will make more power than the EZ and flashpack stacked. Not good to stack boxs on a 24v. The CRs can take it but not so much the 24v's. Add the FASS, put the Comp on, and hold on!
Old Nov 21, 2011 | 02:38 PM
moparious maximus's Avatar
Dont get me wrong, the EZ is a good box and I like the one I have but if you are looking to make good power dont even bother with the EZ, put a comp on it and dont look back.
Like its been said a thousand times before, you must have a good lift pump. I had pretty lousy fuel pressure even with the EZ, that is until I put the raptor on it.
justinsbeck
Jan 18, 2016 12:15 AM
Kfohne21
For Sale
Dec 23, 2014 04:17 PM
somarillw
Dec 8, 2014 09:07 PM
CumminsCrazed
Oct 27, 2014 09:02 PM
