Tranny problem...SUNCOAST STAGE V rebuild
Old Nov 12, 2011 | 06:51 PM
12vCummins94's Avatar
Default Tranny problem...SUNCOAST STAGE V rebuild
If anyone has any idea what would be doing this, id appreciate it BIG TIME!!
Between yesterday and today, when im cruising, foot on the throttle going one speed on the freeway, it keeps going in and out of OD...jumping rpms, but not slipping at all, in fact it shifts smooth and hard through the gears..
Any thoughts bombers?!
THANKS!
Old Nov 12, 2011 | 07:19 PM
mysterync's Avatar
Throttle position sensor out of adjustment, throttle valve out of adjustment.
Old Nov 12, 2011 | 07:21 PM
Dallas Flywheels's Avatar
Sounds like T.P.S.
Old Nov 13, 2011 | 04:14 PM
Okay cool! Is this an easy fix that i can do myself? or should i take it to a tranny shop?? i have a good one close by. Appreciate it!
Old Nov 14, 2011 | 05:59 PM
chrislib's Avatar
Old Nov 15, 2011 | 12:40 PM
Thanks for the vid! Before i saw your post, i actually took the throttle position sensor off and throughly cleaned it with electrical contact cleaner, and played with the little mechanism for a bit, cleaning it and loosening it up a little, also cleaned all the ground and re wired all the positives to my drivers side battery. AND IT WORKS!! My truck is no longer hunting O/D at 50mph+ and running smooth as ever. thanks y'all!
Old Jan 9, 2012 | 03:23 PM
LOOKS LIKE THE PROBLEM IS BACK!! Hopefully someone can help me figure this out! Still hunting OD, tcc locking/unlocking at freeway speeds..
I replaced alternator, regrounded all grounds, put in BD APPS noise isolator, and even replaced TPS to find that it still had same issue so i returned the TPS!
Any ideas???
Old Jan 9, 2012 | 03:38 PM
mysterync's Avatar
Replace the bell crank and bushings and make the tps adjustable or just delete it.
Sent from my DROID BIONIC using Tapatalk
burndiesel
10
Feb 7, 2023 01:15 AM
dieselpowa
Sep 12, 2015 05:28 AM
tim12valve
9
Apr 21, 2015 05:51 PM
davidthomas
Mar 24, 2015 12:41 AM
Ol' RED!
Dec 11, 2014 10:00 AM
