Help Squeeling noise from the motor
Old Nov 12, 2011 | 06:47 PM
canada204's Avatar
Default Help Squeeling noise from the motor
Alright so the best way to describe the noise is when you have a squeeky belt or idler tensioner pulley bearing etc. So thats what I did today changed the belt checked everything out and I still can here the noise I also took off the belt and let the truck run and still hear the noise?
Truck has 109000 miles
So what could it be its not a knock or a tic its a squeel.
does the power steering pump run of a gear from the motor?
I had my lift pump, fuel filter and fuel shut off valve changed could they have installed something improperly?
Seems like the noise is coming from the middle of the motor maybe a little lower hard to tell.
Thanks for the help
Old Nov 12, 2011 | 07:00 PM
Whit's Avatar
Site Mascot
prolly a dry bearing on the idler or tension sheave as some call it, its a sealed bearing so it cant be greased, mine went out around 120k
Old Nov 12, 2011 | 07:17 PM
canada204's Avatar
Thanks for the reply that's what I thought it was and had bought the idler however I took the belt off and let the truck run with no belt and the noise is still there
Old Jan 30, 2012 | 09:58 PM
Berl2169's Avatar
any resolutions to this problem?
Old Jan 30, 2012 | 11:23 PM
canada204's Avatar
It was a bad lift pump I pin pointed it witha mechanics stethascope 9 bucks at autozone hope that helps
Old Jan 31, 2012 | 07:32 PM
Colton Carter's Avatar
Default Cheap stacks
Is there any websites that have good, cheap black stacks for sale?
Old Feb 1, 2012 | 08:40 AM
ricet07's Avatar
Put a post in the price quote and someone will get you some numbers to work with.
Shun70
Sep 20, 2015 10:52 PM
Boatman
Mar 20, 2015 10:00 AM
Dak_summers
Jan 22, 2015 08:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
Dec 3, 2014 09:40 AM
