12v fuel plate installed.!
Old Nov 12, 2011 | 01:22 PM
98250012v's Avatar
Default 12v fuel plate installed.!
whats going on guys.i just installed a bully dog stage 2 fuel plate into my 98 12v.
everything when smooothly break off screw etc.the guy i bought the truck from never put it in but he put in the stage 2 bully dog injectors 215hp box says.
my problem is the truck doesnt feel like it has anymore power what so ever. fuel plate was full forward and 1\16 back. afc and starwheel where pushed back.
i have a upgraded torque convertor.i just feel like this this should be moving alot better than it does checked all the intercooler piping and boots found no leaks. wish one of you guys lived around acushnet mass to help out. someone please give me any information in regards to more power i dont wanna go crazy just a little more pep in the step and some better mileage.
thanks jamison
Old Nov 12, 2011 | 02:00 PM
turbo2332's Avatar
what plate came out of it. did you piddle with the AFC or was it pre piddled with? those are pretty big injectors... what other mods do you have? did you notice any more black smoke? if you just keep dumping fuel in it you not gonna see much of a boost in performance.
Old Nov 12, 2011 | 02:33 PM
98250012v's Avatar
the plate was stock that came out of it break off screw was still there the kit from bully dog came with a brass fitting and i did not install it.the afc has not been touched.untill today
the brass fitting is a boost fitting correct.?? if so how do you adjust it i don't have gauges i'm broke so i know i should but i don't romp on the truck i just drive it 4inch exhaust bully dog intake with k.n filter the injectors say stage 2 on the box 50 hp
thanks for anyhelp and suggestions first time owning a CUMMINS.
Old Nov 12, 2011 | 02:43 PM
turbo2332's Avatar
is it the adjustable one with a set screw in it? ya just put it in and leave it alone till you get gauges. it should put you around 28-30 psi. you really do need a pyro with those big injectors. the boost elbow will go into the back of the AFC on the line that runs to the turbo. you can also install it on the turbo.
Old Nov 12, 2011 | 03:17 PM
98250012v's Avatar
ok so i should put that in cause i feel the fuel plate made no difference at all i don't care for smoke i want good mileage.me and my buddy put the fuel [plate in today everything as i said went well we put the afc ff towards the intercooler and turned the starwheel back about 3\4 and it feels the same. so thats why i don't know if i need that boost fitting on to make a difference.
oo and yes it is adjustable with a little screw in it.!
ok well like i said im new so dont thrash me for tis but the guy said he put a newer turbo it say holeset 25 on it and the is only one line that goes to it the goes from the top of the oil filter houseing to the turbo and then i see no other lines i dont even see a wastegate.and one metal pipe from the turbo to the motor.my buddy has a 96 and the wastegate is there and there is a line in the front of the turbo i think your talking about but my turbo has it looks to be a allen or a torx in there.??
and the only line i see coming off the afc is going straight to the bottom of the valve cover.
Old Nov 12, 2011 | 03:25 PM
turbo2332's Avatar
pictures... you should have an HX40 and it should have a VIN tag on the compressor housing telling you what it is.
Old Nov 12, 2011 | 03:29 PM
98250012v's Avatar
how to post pictures
Old Nov 12, 2011 | 03:34 PM
turbo2332's Avatar
beats me? i havent done it i think you copy paste them into the text?
Old Nov 12, 2011 | 03:40 PM
98250012v's Avatar
there is no vin tag and my phone is updating stupid thing but the compressor housing says lm25s holeset the vin tag is gone and there is no wastegate and or line.??
Old Nov 12, 2011 | 03:45 PM
98250012v's Avatar
these are the pictures
Attached Thumbnails 12v fuel plate installed.!-turbo1.jpg   12v fuel plate installed.!-turbo-2.jpg   12v fuel plate installed.!-turbo-3.jpg
